Car Cutting Out
Old Dec 23, 2010 | 09:20 PM
JonnyAlpha's Avatar
JonnyAlpha
Default Car Cutting Out
Hi;
After turning off my Focus earlier today running fine it would not start, all lights come on but nothing when I turned the key. Tried three times no joy, then the wife jumped in and it started first time. Then later today whilst parking the car just cut out and would not start, lights all on but nothing when I turned the key, checked the battery electrolyte and connections, fuses and relays and any visible cabling, jumped back in the car and it fired up.
Is this an immobilizer or engine management problem or just the cold?
Ford Focus 1.8. Ghia 52 Plate
Old Dec 28, 2010 | 03:50 PM
blackbeautyzetec's Avatar
blackbeautyzetec
check the black ground cable on the left of the engine matey.
if it looks bad. change it
Old Dec 30, 2010 | 05:17 PM
You'll see if it is a immobiliser issue from the light behaviour, if it is wipe the key with a damp cloth, may be a bit static interfering.
Fordmad!
Sep 26, 2015 05:24 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
john_3.0s
Aug 15, 2015 07:44 AM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
