Help!!!!!
Old Dec 22, 2010 | 03:11 PM
kcosneil's Avatar
kcosneil
Default Help!!!!!
Escos missing on number 1 cylinder. its not the spark plug, ht lead,phase sensor,ignition amp,dizzy cap,coil. Its getting fuel. Any help would be great.
Cheers neil
Old Dec 22, 2010 | 03:16 PM
timrud's Avatar
timrud
Have you tried all those parts on another engine?
Old Dec 22, 2010 | 03:22 PM
kcosneil's Avatar
kcosneil
There all new !! And ive swapped two spark plugs over and two ht leads. The problem stays with number 1 cylinder.
Old Dec 22, 2010 | 03:23 PM
Alvyn's Avatar
Alvyn
what happened prior the problem? do a compression test?
Old Dec 22, 2010 | 03:25 PM
FletchCossie's Avatar
FletchCossie
Join www.EscortRSCosworth.com mate
Old Dec 22, 2010 | 03:26 PM
timrud's Avatar
timrud
I'm always a bit sceptical about new parts, they might be faulty too! Until I've seen them working I don't trust them.
But should they all be working OK, I'd be looking at a compression test next.
Old Dec 22, 2010 | 03:28 PM
kcosneil's Avatar
kcosneil
Nothing just stopped working. Gona do a compression test when i can.
Old Dec 22, 2010 | 03:30 PM
kcosneil's Avatar
kcosneil
Originally Posted by FletchCossie
All ready on there fella
Old Dec 29, 2010 | 01:23 PM
kcosneil's Avatar
kcosneil
done a compression test there all inbetween 148-151 psi. i said its gettin fuel but im not sure. is there any way of testing the injector.
this is doing my nut in now errrr!!!!
Old Dec 29, 2010 | 03:29 PM
kcosneil's Avatar
kcosneil
its not the injector i swaped two over.
Old Dec 29, 2010 | 08:18 PM
bigjohn0's Avatar
bigjohn0
You said you have changed the plugs and leads ...... Just go back and check to make sure you have got the fireing order correct
Old Dec 29, 2010 | 08:43 PM
vaughant's Avatar
vaughant
Wiring to the injector?you've just done the head iirc so a wire could easily have been damaged as they get very brittle over time.
Bell it out on your multimeter and give the wire a wiggle as well to see if the readings change.check the connector on cyl 1 injector spade hasnt popped back in therefore not making a connection.
Basic checks really as the cars obviously been running ok up until now.
Old Dec 29, 2010 | 08:45 PM
Danny @ Enhanced Performance's Avatar
Could be water getting in there??any other symptons??
cheers danny
Old Dec 29, 2010 | 08:59 PM
vaughant's Avatar
vaughant
Another way of checking the wiring would be to pull the injector out and try turning it over.you should get petrol out of it if alls well?I'd try the continuity test with the wiring first,I've been caught out on a Clio before with exactly that.
Old Dec 29, 2010 | 09:36 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
if the plugs on injectors are long enough, swap 2 plugs about for instance if cyl 4 isn't firing, swap #4 injector plug onto #3 and vice versa...that should eliminate wiring/ECU.
Old Dec 29, 2010 | 10:17 PM
vaughant's Avatar
vaughant
Another technique would be to tap into the wiring to measure voltage when running at that injector.
Old Dec 29, 2010 | 10:31 PM
vaughant's Avatar
vaughant
Would you also need to swap the corresponding plug lead?I'm just thinking if the ecu squirts the injector in on wire 1 but you've actually got injector wire 2 connected to prove a fault won't the misfire actually be worse as the spark for 1 will come on as usual yet the injector will squirt into cyl 2 as the ecu thinks it's actually 1 and vice versa.would swapping the leads to the respective cylinders cure this;I.e swap inj plug 1&2 and ALSO lead 1&2 so the fuel and spark correspond via the "tricked" ecu,if that makes any sense at all!!!!
Old Dec 29, 2010 | 11:59 PM
kcosneil's Avatar
kcosneil
ive swap two injectors over and the problem stays with no'1 so it cant be the injector.
ive pulled of the plug and put a multimeter on it and its getting voltage.
what does the ignition amp do?
Old Dec 30, 2010 | 09:12 AM
GUZZLER's Avatar
GUZZLER
I heard it go past the other day, I wouldn't drive it like that, how does the spark plug look? You need to make sure the cylinder is getting air, fuel & spark at the right time.
Are Powers not open today or is Eyeball away?
Old Dec 30, 2010 | 11:53 AM
kcosneil's Avatar
kcosneil
all right matt long time no speak hows the family. where were u then?
the f'ing thing is doing my head in im this close to putting it in a field and torching it!!!!!
Old Dec 30, 2010 | 12:13 PM
pee vee's Avatar
pee vee
If it is DEFFO getting all the right ingredients. spark, fuel and air
then it can only be an issue of timing.
so have a quick check that the timing marks all line up.
if so, then you cant be getting one of the other 3!
Old Dec 30, 2010 | 12:16 PM
kcosneil's Avatar
kcosneil
i'll look at the timing in a sec but its defo only missing on cylinder 1. i say missing its not working at all.
Old Dec 30, 2010 | 12:21 PM
pee vee's Avatar
pee vee
hmm. is the spark plug wet when you take it out?
Old Dec 30, 2010 | 03:35 PM
kcosneil's Avatar
kcosneil
problem sorted people there was the smallest of breaks in the depths of the loom earth wire which went to number 1 cylinder.
thanks everybody for your help
neil
Old Dec 30, 2010 | 07:41 PM
vaughant's Avatar
vaughant
neil
Great stuff!!was it the injector earth or another earth?I had to solder minuscule amounts of wire into the Clio loom,some stupid rubber mounting thing had worn it right through.
The injector plug would still show voltage if if you measured live to body earth but it should have been dead if you measured between plug live and plug earth?often,as they bend round the the plug onto the injector that's where they go.
Glad you sorted it.
