1.3 for 1.6
Old Jan 30, 2005 | 12:39 PM
marky_g's Avatar
marky_g
Fleet Manager
Default 1.3 for 1.6
hi dose any one know if i can just SWOOP a 1.6 chv where i used to have a 1.3 hcs, the 1.6 will also have electronic ignition acd a carb can it be done?
what will i need to chenge?
will it work srtaight swoop ?????
please help thaKsh alot
marcus gent---pm me
www.gofigurecarclub.co.uk
Old Jan 31, 2005 | 11:44 AM
rich2302's Avatar
rich2302
The HCS engine is the crossflow lump I think, you could get an engine from a mk1 XR2 if you can find one and that should work.
If you do want a CVH then you will need the complete engine including the engine mounts and both inlet manifold with carb and the exhaust system.
The dizzy should be easy enough to wire in.
What car is it for?
Old Jan 31, 2005 | 12:50 PM
marky_g's Avatar
marky_g
Fleet Manager
nah ovh for cvh is straight swoop just need to know about the electronic ignition used on later HCS and CVH lumps
OH the car is an escort MK4
mk3ste
Oct 17, 2021 10:09 AM
mondeomark
Sep 28, 2015 06:28 AM
sridgett
13
Sep 27, 2015 06:03 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
