xr3i efi problems
Old Dec 15, 2010 | 09:47 PM
harvcore's Avatar
harvcore
Default xr3i efi problems
car has new battery and altenator
recently the car doesnt start when hot like battery is dead ,if i push it ,it will start
starts no problems when cold
is it some sort of sensor or is the engine on way out as its burning oil and it had valve stem seals 3 months ago ie compression issues ?
Old Dec 16, 2010 | 09:45 AM
martysmartie's Avatar
martysmartie
It sounds as if the starter motor may be getting cooked. The ERST is renowned for this problem due to the proximity between the starter and the turbo obviously this does not apply to yours. Do you just get a clicking sound?
That engine is known for the stem seals causing oil loss, you need to determine how it is burning it, I.E on the over run etc, if you done the stem seals I suspect bottom end wear perhaps.
Martin
Old Dec 16, 2010 | 10:10 AM
harvcore's Avatar
harvcore
Martin
It sounds like the battery is flat
and i suspect the rings are going due to smoke and smell from tailpipe
Old Dec 16, 2010 | 10:13 AM
martysmartie
Have you checked the earth's are good?
Martin
Old Dec 18, 2010 | 07:37 PM
gcfcos's Avatar
gcfcos
i second the starter motor sounds like its knackered
Old Dec 18, 2010 | 09:54 PM
harvcore's Avatar
harvcore
thanks guys but the car started tonight and i went to the shops and it didnt start when i returned and i had to get a jump start ,it sounds like the battey is flat but it isnt ,it seems to be ok when cold and impossible when hot
Old Dec 20, 2010 | 05:19 PM
harvcore's Avatar
harvcore
does this engine have a cold start valve or similiar thats not working correctly ?
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
dms04
Sep 11, 2015 01:57 PM
