cosworth engine bearings
Old Dec 14, 2010 | 02:25 PM
YBT200's Avatar
YBT200
Default cosworth engine bearings
hi, does anyone knows from where to buy ford original bearings both big-ends and mains in std please
Old Dec 14, 2010 | 02:28 PM
chaffe's Avatar
chaffe
Turbocharging Technician
why does it need to be original ford? Acl make good bearings for lots of manufacturers and applications, probably even ford
Old Dec 14, 2010 | 03:12 PM
daviddunlop83's Avatar
daviddunlop83
You can get them from ford but they are a fortune.
As said buy another makeor tru cosworth direct for them as i got genuine ford ones from there.
Old Dec 14, 2010 | 03:17 PM
Cossy Mike's Avatar
Cossy Mike
Cosworth
http://www.cosworth.com/Default.aspx?id=1095008
Old Dec 14, 2010 | 07:30 PM
YBT200's Avatar
YBT200
acl bearings don't last long from experience on drag racing cosworths, ford originals are more good quality!!
Old Dec 15, 2010 | 01:04 PM
Mark RS's Avatar
Mark RS
Ford
Old Dec 15, 2010 | 01:38 PM
chaffe's Avatar
chaffe
I would say then that there is an oil pressure/supply/grade problem as the bearing itself should never actualy touch the crank, ive seen engines with over 100,000 miles and the bearings are still like new, maybe with only the slightest hint of where a stray piece of carbon has scored them.
Old Dec 15, 2010 | 01:41 PM
chaffe's Avatar
chaffe
Old Dec 16, 2010 | 11:09 AM
Fezman1's Avatar
Fezman1
GGR do the Vandervell mains and big ends std size for £60. or 0.25 for £75.
Always sware by these myself.
Theres always Mahle Motorsport shells, Matt Lewis does them.
Old Dec 22, 2010 | 10:43 AM
YBT200's Avatar
YBT200
what bearings and oil pump are you using ?
Old Dec 22, 2010 | 11:05 AM
AndyR1's Avatar
AndyR1
ive used acl and mahle with a 5 bar pump both have been used in 450 bhp engines with no pronlems ,matt lewis sells both
Old Jan 6, 2011 | 08:58 AM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Mahle IMO is the way to go, i have been advised by ford that they do not have lower main bearings in stock.
Old Jan 6, 2011 | 09:04 AM
daviddunlop83
Have they still not got this sorted. I remember when i got all my stuff cosworth said they were trying to source a new supplier for the bearings but luckily ford had them in stock as i already had the upper half so i needed the lower
That was a couple years ago so im suprised they havent got this sorted
Happy New Year Matt
Old Jan 6, 2011 | 09:06 AM
Matt Lewis's Avatar
Matt Lewis
I think COSWORTH went and used ACL in the end mate
Happy New Year to you aswell
Old Jan 6, 2011 | 02:14 PM
PAUL S's Avatar
PAUL S
The Vandervell ones I bought from GGR were stamped with the Ford logo so they may still have some in stock if you require ford spec ones
Old Jan 6, 2011 | 03:11 PM
YBT200's Avatar
YBT200
vandervell are good bearings !! i think i will give them a call!!
Old Jan 6, 2011 | 04:14 PM
Matt Lewis's Avatar
Matt Lewis
also be careful that they are the correct bearings (Not Pinto) which i would assume they are from GGR
Old Jan 6, 2011 | 04:27 PM
DAN400's Avatar
DAN400
id like to know the difference in pinto and cosworth bearing, i ve always used pinto bearing s for my engine and so have my mates, never had a problem
Old Jan 21, 2011 | 05:46 PM
MAHLE's Avatar
MAHLE
MAHLE UK
pinto main bearings are fully grooved (360 degree), YB bearings use a plain bottom shell - the plain shell gives a higher load bearing capacity. A lot of pinto bearings are also a lower grade material.
Rod bearings are dimensionally the same, material specification differs.
Only bearings I have seen which have the plain shell are OE Ford or our own Motorsport range. Not sure about Cosworth, but if as is stated earlier they are now purchasing from ACL then they will also not be a plain bottom shell.
Regards,
MAHLE
Old Jan 21, 2011 | 08:05 PM
RS SHAUN's Avatar
RS SHAUN
how much are the standard mahle's matt?
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
