"standard" wiring loom?
Old Jan 29, 2005 | 09:16 PM
chorton's Avatar
chorton
Default "standard" wiring loom?
Scenario is this:
My S2 Has not got electric mirrors fitted
My Garage does have a set of electric mirrors and a switch in it.
Question is this:
Do all turbo's have the same wiring loom fitted as standard meaning I will be able to just find the right connectors lurking behind my dash somewhere, enabling me to plug in and go?
Old Jan 31, 2005 | 11:46 AM
rich2302's Avatar
rich2302
Should be ok, I cant imagine for one minute that it would be hard to wire up if it wasnt there
Old Jan 31, 2005 | 12:14 PM
sufsRS's Avatar
sufsRS
im sure it is because a m8 wanted 2 put a fuel computer into his and found the plug behibd the dash, just have a check m8 shud be their
Old Feb 2, 2005 | 05:02 PM
Damo V's Avatar
Damo V
there will be a plug behind dash amongst main looom, to the right of the clocks if you remiove thise first
Old Feb 4, 2005 | 10:55 PM
Al Bags's Avatar
Al Bags
Hi ..
You need to check for the Electric mirror subloom. This connects up at each lower A-panel (conical connector) the RHS mirror (motors and heater) the LHS one, and the mirror control panel, clipped across the bulkhead with the other main wiring - The other sublooms (if fitted) are Heated screen, and Central Locking control. If the wiring isnt fitted, you can add quite easily. You have a heater wire (Black/yellow) Power (red) from fuse3 maybe, and an earth (brown) to connect up.
All this is pretty straightforward. The hardest thing, if you have to fit a subloom, is dragging it across through the clips, especially behind the steering column reinforcement. I think you'll find you dont have the wiring subloom fitted.
I fitted all of the above lot on my '86 van, along with a Turbo dashboard, and it's cool to get it all working. Tip .. Keep the A-panel connectors silicone-greased up ; )))
Good luck!
Old Feb 7, 2005 | 10:03 AM
Damo V's Avatar
Damo V
I am 99.9% certain the plugs will be there to add the extra wiring for the mirrors, They were an option when new and Ford wouldnt simply produce 2 looms 1 with the loom plugs (if people added them) and one without the loom plugs..
The reason they werent on your van loom is because they werent an option on the vans
Old Feb 7, 2005 | 03:56 PM
chorton's Avatar
chorton
excellent info thanks ppl!
Just had a look, Looks like I need to find myself a mirror sub loom!
Old Feb 7, 2005 | 09:37 PM
nicksaph's Avatar
nicksaph
my mate had a s2 and it didn't have the wireing for a computer
Old Feb 7, 2005 | 09:52 PM
Al Bags's Avatar
Al Bags
You can use one from an Orion .. same parts.
It's one-piece . LHS A-Pillar plug to Control switch, then to RHS A-Pillar plug.
Make sure you have the connectors at the A-pillars, or you will need the two door jumpers (with rubber grommets/tubes) too. Trust me .. that one will connect to everything. I used Orion Ghia i parts for my van.
Damo is partly correct. We build cars now using many different variants .. They are built with different wiring with various features..... but we SERVICE with a reduced number ... as many as will allow features to be supported.
The new Focus has around 30 different wirings for drivers door! We service with about 10.
Mk 4 was done a bit different, using add-on wiring for most extra services such as Central-locking, Mirrors, etc
The reason I went to such lengths before is .. cos that is part of my job at Ford .. Wiring!
Old Feb 7, 2005 | 09:57 PM
chorton's Avatar
chorton
Cheers Bags! Some dead handy, well detailed info there mate! Keep up the good work
Old Feb 7, 2005 | 10:37 PM
Al Bags's Avatar
Al Bags
Your welcome ....
PM me if you get stuck .. When you rebuild, weld, maintain and upspec an '86
van, you get to know them like the back of yer hand.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
IainRS1700T
Sep 25, 2015 06:44 AM
