How much play is normal on a turbo?
Old Jan 29, 2005 | 03:17 PM
chorton's Avatar
chorton
Default How much play is normal on a turbo?
Basically I want to know how much play is normal on the turbine in my turbo. Iv'e read that a"bit" of play is normal, so how much is a bit? I've got about 2, maybe 3 mm of left to right play, but no noticable in/out play. I also have oily residue in the intake pipe from the intercooler, and also in the pipe coming from the charge carrier. Any advice greatly appreciated, I think the turbo's knackered! p.s. There is a small amount of blue smoke on decelaration, none on start up.
Old Jan 29, 2005 | 04:00 PM
MK5RST's Avatar
MK5RST
Oil in the intercooler is normal unless you have an aftermarket breather system which directs the oil back into sump
Old Jan 29, 2005 | 05:32 PM
ballin's Avatar
ballin
a little side to side movement is okay, but any in/out and you're struggling!
ballin's Avatar
ballin
just re-read it sorry! 2mm is fine the bearings will take that up when it warms up
Old Jan 30, 2005 | 09:04 AM
adamS2RST's Avatar
adamS2RST
Sounds ok to me, of course if it sounds like its struggling or it is smoking then it may need an overhaul
Old Jan 30, 2005 | 09:45 AM
chorton's Avatar
chorton
So whats the most likely cause of a bit of blue smoke occasionally after hard accelleration?
Old Jan 30, 2005 | 10:00 AM
wimwerf's Avatar
wimwerf
up and down...1mm....inside and out nothing....
Old Jan 30, 2005 | 07:36 PM
rsnitrouskev's Avatar
rsnitrouskev
u will get some play cos the turbos not under pressure
Matt Baxter
Sep 16, 2015 08:30 PM
Danielbetty
Aug 23, 2015 12:52 PM
IAN RS2k
Aug 18, 2015 07:51 PM
muz
Aug 16, 2015 12:57 PM
rs_turbo_ant
Aug 8, 2015 11:11 AM
