1.6 to 1.8 or 2.0
Old Dec 6, 2010 | 06:53 PM
SWIFTY's Avatar
SWIFTY
Default 1.6 to 1.8 or 2.0
Some one I work with has a 1.6 zetec and it's drinking oil having to fill up every 2 days there is not smoke and he parks it on a cream carpet and there is no sign of oil there, so he wants to put a new engine in could he put a 1.8 or 2.0 in would it be a straight swap including starter motor ect
Thanks
(sorry spelling might not be great)
Old Dec 6, 2010 | 06:54 PM
LukeDaisley's Avatar
LukeDaisley
in what?
Old Dec 6, 2010 | 06:58 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
what car is it mate
Old Dec 6, 2010 | 07:03 PM
phil_focus's Avatar
phil_focus
its in the focus section guys so it can only be a focus...
Old Dec 6, 2010 | 08:15 PM
LukeDaisley
good point.
Old Dec 6, 2010 | 09:13 PM
hogdog's Avatar
hogdog
The only straight swap is the 1.6, the 1.8 and 2.0 engines are completely different.
Old Dec 6, 2010 | 09:36 PM
martysmartie's Avatar
martysmartie
The Zetec-SE it currently has fitted and the Zetec-E either in 1.8 or 2.0 guise are completly different engines, it's not worth the time nor the expense in doing so.
A few basic things, the inlet and exhaust are on opposing sides to start with and so you need to change the exhaust, you then need ECU etc, theres a whole load of other things to, IMO better off just having the engine rebuilt or replaced with a equivilant.
To add in the real world at least in standard tune anyway, it's a known fact there is very little difference between the 1.6 and 1.8, acceleration is around the same although obviously the 1.8 has better mid range grunt and after you done so you would have +15HP at the best for your effort as this is the power difference between the two.
Martin
Old Dec 7, 2010 | 11:50 AM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
Don't bother.
Just don't
Old Dec 7, 2010 | 04:57 PM
SWIFTY's Avatar
SWIFTY
Thumbs up
Thanks
Will just swap it like for like as I think it will be easier an prob cheaper than rebuilding.
Old Dec 7, 2010 | 05:10 PM
martysmartie
It may be something simple like oil getting past the valves? These engines are good for big miles!
Martin
mk3ste
Oct 17, 2021 10:09 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
mondeomark
Sep 28, 2015 06:28 AM
liamT74
Sep 23, 2015 10:24 PM
