Pug 405 blowing cold air
Just picked up a 405 as a cheap winter hack whilst the escorts tucked up away..only prob is the heators only blowing cold air, Its a 2.0ltr diesel
.. anyone got any ideas as the idea of cold mornings again arnt exciting me
Cheers guys..not had a chance to run the car up to a full temp as its only gone 2 mins round the road and got the battery on charge (been parked up 3 months).. The gauge does move..highest it read is 70 so far.. will have a look in the daylight after the batterys had some time to recover
Right update..
Managed to get the car up and running with a new battery. In normal driving conditions the temp sits between 70/90 on the guage only after a long spell in traffic/stioanry does the gauge move it then moves to 90/95 but once back on the move drops to 80. Rads getting hot all over, and the two heator pipes at the rear are warm but not roasting (you can hold them for a few mins easy).. Im guessing to unblock it its a case of venting either 1 of the 2 valves on the right (look like tyre valves) and hearing the air hiss out?
Right update..
Bob
No air con on mine so guessing the valves are standard fittment.
Found a manual in the boot so ill have a look at the thermastat and the bleed screws seem easy enough (looks rather blue peter needing a litre bottle lol), But ive got another thought. The cars got slider heator controls and the temp adjuster moves a bit to easy as if its not attached to anything am i right in thinking that the resitor packs for pugs used to break?
Sounds like a job for sunday then.. looking at it n checking the fluids etc its not long had a service so ill start with the air lock before stripping the dash pannel.. French cars hey..
I've had my 405 from 7 months old and it has been a great car and still in daily use. No complaints here on French engineering.
My Cmax has a Ford-pug engine in it so plenty of French influence there too.
All I need is the answer to my question about the flash codes to see what it is trying to tell me. My local Ford Agent does not know but there are a bunch of brain donors.
A while back the auto headlights were playing up and they got a new sensor under warranty and then asked ME where the sensor was located so they could fit it!!
Bob
Bob
The same problem applys to the recirculate flaps too.
Bob
either way its getting into the dash to have a look.. someone did mention bout there being a little black box behind the heator that controls the temps.. Cheers for ya help Bob.
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
