chrome wing grills
Old Dec 4, 2010 | 12:04 PM
lukeyboy's Avatar
lukeyboy
Default chrome wing grills
hi brought some chrome wing grills but not to sure how to fit them cos the old plastic grills look luke they are rivited on anyone know how to get them off.
cheers
Old Dec 4, 2010 | 12:23 PM
Turbosimpsons's Avatar
Turbosimpsons
knock the middle of the plastic (clip thingy) out don't loose them as you can re-use them. the rest will pull out then your grills will come off.
Old Dec 4, 2010 | 12:37 PM
lukeyboy's Avatar
lukeyboy
how do you knock them out is hard
cheers
Old Dec 4, 2010 | 03:08 PM
Turbosimpsons
you need a small diameter drift. if you look closely you'll see the centre bit that needs knocking out. unless someone has rivited them on. then you need to drill the rivets out. can you get a photo up.
Old Dec 4, 2010 | 06:05 PM
j6kyt's Avatar
j6kyt
push them out with a small screwdriver, i have them fitted but i used small stainless round top allen screws they real look good.
Old Dec 6, 2010 | 03:20 PM
lukeyboy's Avatar
lukeyboy
where did you get the stainless round top allen screws from
cheers
Old Dec 6, 2010 | 03:29 PM
lukeyboy's Avatar
lukeyboy
hi yeah i can get photos up
cheers
Old Dec 12, 2010 | 07:50 PM
j6kyt's Avatar
j6kyt
cheers
you can buy thefrom r/c controlled car shops they were in my spares box.
Old Dec 24, 2010 | 02:49 PM
cossiefrank's Avatar
cossiefrank
you can them from screw fix as i used them on mine. Frank
Old Dec 26, 2010 | 01:47 PM
Dunccoss's Avatar
Dunccoss
what you want to do is push the center rod back out from the back of the wing (jack car up at front and turn wheel round on full lock and look in arch at the back of the grill plates) as that way you wont lose the small tube that runs in the center of the clip and expands the rear of the clip out to hold the grill on, just use a small drill bit to push the tube out and then pull the clip
gcfcos
59
Oct 6, 2015 05:04 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Iain Mac
Sep 30, 2015 09:39 PM
