TRansit sportvan Stereo gone batsh!t
got in my van today and column control for radio wouldnt control stereo,then 5 mins later radio starts carrying out the commands i did with the column control but with no control over the stereo via facia buttons
then it decides to only play cd6 (6-player unit) but in fast forward mode,then i switch it of it will switch back on and play only cd6 i have no control at all now....
is it just the cold that has got to it and will eventually right itself or am i gonna have to bin it and dig out my multimedia alpine setup from the garage to install now
can anyone shen any light please
Ta
Ta
it's normally caused by the cold, i know loads of ford radio's, especially the 6 disc models that do this
is this the same as the mondeo one or is it the earlier version with the removable front security panel?
right all its done for last week is scan,facia buttons do naff all,steering column control when volume buttons pressed will play the nearset station but volume rises or drops dependant on which part of column control is pressed...
it is buggered? cant even eject my pet shop boys cd now
yes mate by just about 6months,i think its the steering columb stalk control thats snafu`d,gonna try disconnect from main unit,does anyone know if will just unplug from the back of the stereo and which plug it will be
if you've got the code just unplug it and leave it out for a while
the car stereo went a bit loopy yesterday after being in the cold, but once it warmed up it was fine
i would probably go with the "condesnation inside the unit has fried it" theory if pushed, but you can get new ones for about £50 off of ebay
£50?? Its a 6 disc jobbie will look tho,had fancied fitting my alpine multimedia kit tho
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
