S2 owners...Front tension strut conversion, like S1 set-up.
Old Jan 28, 2005 | 11:13 PM
MEF's Avatar
MEF
Former Sponsor
Default S2 owners...Front tension strut conversion, like S1 set-up.
OK, here's another idea to whet your appetite:
I am looking at producing a bolt on kit for the S2 Turbo to fit front tension struts. This would enable the uprated tension strut kit that I already market to fit S2 Turbo's. This allows fully adjustable front castor and proper location of the TCA, leaving the ani-roll bar to do it's job properly, on it's own!
The kit would consist of a sturdy powder coated steel front crossmember that would bolt up between the existing corner plates and carry brackets for the front ends of the tension struts. There would also be brackets to carry the existing anti-roll bar in its existing clamps. (it would be moved forward of its existing location) The anti-roll bar would connect to the tension struts with alloy clamps as per S1 turbo & RS1600i which would be part of the kit. There would be no modifications necesary to the chassis or to the gearbox cradle.
How does this sound? Anyone interested? Is there a market for such a kit? If so I will get it sorted and in production!
Comments please!
Martin
Old Jan 28, 2005 | 11:46 PM
bassboy's Avatar
bassboy
u know im interested as per normal
bassboy
Old Jan 29, 2005 | 09:29 AM
NUTS RuS's Avatar
NUTS RuS
I have an order here already...
This does away with the £400+ no longer available, Turbo Technics upgrade for the S2, and also betters it by using CDS thick walled tube and proper rose joints for the tension struts.
Old Jan 29, 2005 | 10:40 AM
Hartyboy's Avatar
Hartyboy
What sort of price mate
Old Jan 29, 2005 | 11:14 AM
MEF's Avatar
MEF
Former Sponsor
Dont know yet, it's only at the very early design stage so it depends upon many things. If I simply make some brackets on a crossmember to take the tensions struts then it will be £195 for the tension struts plus whatever the crossmember costs to make. The complication is the antiroll bar and its mountings. Having done some evaluation this morning on my "development vehicle" I looks like it wont be possible to use the standard antiroll bar at all, the choice will be to either run without one (as per NutsRus RS1600i) so no additional cost or add brackets and use an RS1600i or S1 turbo ARB with alloy clamps, obviously more expensive. Anyone know if these are available brand new from Ford? I doubt it!
Martin.......back under the car for more thinking!
Old Jan 30, 2005 | 06:37 PM
oriont's Avatar
oriont
sound good i would be interested in this too.
thanks
oriont
Old Jan 30, 2005 | 07:33 PM
Andy-ywk's Avatar
Andy-ywk
I'd be interested in this as well if you do it.
Old Jan 30, 2005 | 07:57 PM
MEF's Avatar
MEF
Former Sponsor
OK, thanks for showing the interest guys. Havn't made any more progress this weekend, have started on the prototye bias pedal box though.
Been re-building my Scooby rally car gearbox and fitting that, top priority as 1st event this year coming up on 19th Feb, North West Stages rally so got to get that sorted before anything else!
Cheers,
Martin
Old Jan 30, 2005 | 08:36 PM
bassboy's Avatar
bassboy
good luck for that martin
bassboy
Old Jan 31, 2005 | 08:12 AM
JesseT's Avatar
JesseT
The S1 alloy clamps are not available from Ford anymore.
Old Jan 31, 2005 | 08:33 AM
MEF's Avatar
MEF
Former Sponsor
Yes, I know the alloy clamps arn't (and they can easily be made) but what about the ant-roll bar itself, can those be obtained from Fords or anywhere else?
Martin
Old Jan 31, 2005 | 02:02 PM
JesseT's Avatar
JesseT
The S1 anti-roll bar is stupidly thin at 18mm. If one would make a run of 24mm S1 antiroll bars they would have takers, I presume.
Old Jan 31, 2005 | 02:13 PM
MEF's Avatar
MEF
Former Sponsor
Well you say "Stupidly thin @ 18mm" but why do you think this? What do you think it will achieve using a 24mm one instead? From my experience with these cars, they drive very well indeed with NO anti-roll bar at all. This is how Ford ran them in GpA rallying back in 1985/6 and I ran mine the same way too, never fitted one it was so good without.
The problem with anti-roll bars is that they inherrently induce understeer, exactly what you want to get rid of! If you have an S1, try disconnecting the alloy block, just on one side and see how it drives, you might be surprised, I bet it has better turn in and less understeer too.
I admit that an a very fast & smooth flowing racetrack you might want a very stiff front ARB but if it's tight and twisty, my bet is that it will be quicker without.
Is the S1 sharper to steer & less understeery, better "turn in" than an S2, if so than that could be caused by the thinner S1 ARB!
Just a thought!
Martin
Old Jan 31, 2005 | 04:42 PM
WutangRS's Avatar
WutangRS
could you modifiy a 1600i one to fit a S2. only reason i ask is that i have both the S1 and the 1600i lying around. i was gonna use the 1600i but it doesnt fit from what ive been told.
Old Feb 1, 2005 | 10:37 PM
MEF's Avatar
MEF
Former Sponsor
Wanted! To help my development work I urgently need a pair of S1 Turbo front cornerplates, front bit that joins them together and maybe the anti-roll bar assembly with it's mounting brackets and rubbers etc. Will buy or loan! Will pay postage etc
Maybe should be on a different thread but it's very relevant to this thread and the future of my conversion ideas.
Thanks,
Martin
Old Feb 2, 2005 | 12:08 PM
nigel b's Avatar
nigel b
ive got a spare 1600i one if its any help
Old Feb 2, 2005 | 12:53 PM
NUTS RuS's Avatar
NUTS RuS
Got one already on its way up Nigel
Old Feb 2, 2005 | 02:18 PM
Davey8oy's Avatar
Davey8oy
Count me in!!!!!!!!!!!!!!!!!!
Old Feb 2, 2005 | 03:16 PM
MEF's Avatar
MEF
Former Sponsor
Still working on this one, I really need to borrow a pair of S1 corner plates to make some progress, have put an ad in the Wanted section.
Meanwhile, thanks for the positive interest, I will let you all know when I've done some development work and got something available.
Cheers,
Martin
Old Feb 3, 2005 | 02:43 PM
Blunt's Avatar
Blunt
Deffo want 1
Old Feb 3, 2005 | 08:01 PM
nigel b's Avatar
nigel b
i dont think it will have any benefit on mine,wont be able to get it any better than what it is
Old Feb 14, 2005 | 09:24 AM
MEF's Avatar
MEF
Former Sponsor
Development is slow going! I'm waiting on delivery of the S1 corner plates.
So far I have noticed that there is a considerable difference between S1 and RS1600i arb's, the S1 fits to the rear of the front x/member whereas the RS1600i one clamps to the x/member in front of the Tension strut pickup points.
Does anyone know if either of these are available from anyone?
Cheers,
Martin
Old Feb 14, 2005 | 10:09 AM
NUTS RuS's Avatar
NUTS RuS
I take it its the ARB's your after now
Old Feb 19, 2005 | 03:05 PM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Am i top of your list Tony/Martin
Old Feb 20, 2005 | 09:03 AM
Rippers's Avatar
Rippers
Monte Geek
Is this what your after mef: http://cgi.ebay.co.uk/ws/eBayISAPI.d...955836547&rd=1
Old Feb 20, 2005 | 09:16 AM
MEF's Avatar
MEF
Former Sponsor
Yes, exactly, buyt I have already bought one now, just waiting it's arrival, hopefully development will commence verey soon!
Cheers,
Martin
Old Feb 20, 2005 | 09:23 AM
Blunt's Avatar
Blunt
mef
Anychance these will be ready before the summer mate?
Old Feb 20, 2005 | 09:52 AM
MEF's Avatar
MEF
Former Sponsor
Definately, I'm hoping that I can get this into production during the next month if possible, the stumbling block will be finding a suitable ant-roll bar for those that insist that it's essential. I am having trouble convincing you lot that you can quite happily run without one, the car won't suddenly flip on it's roof without an ARB!
As I've said before on this and other threads, Ford didn't run one on their GpA rally cars back in the 80's, neither does NutsRus on his well proven and brilliantly handling RS1600i.
Martin
Old Feb 20, 2005 | 10:39 AM
Blunt's Avatar
Blunt
ARB or not am not bothered just wanna get 1 so i can send it off with my other bits
so it will the same set up as a SI withouht the anti rollbar then have you got any pic's ? of nutsrs
Old Feb 20, 2005 | 10:44 AM
MEF's Avatar
MEF
Former Sponsor
OK, sorry, no pics yet but I will post some as soon as I can get the prototypes completed on my development car.
Watch this thread!
Martin
Old Feb 20, 2005 | 10:49 AM
Blunt's Avatar
Blunt
Closely
so i guess they will be avable with or without a ARB for those that want or dont want 1
sorry ofr the Q's LOL
NUTS RuS's Avatar
NUTS RuS
Mine uses the standard RS1600i ali front crossmember Blunt as its lighter I have the Mk3 gearbox mounting not the cradle so its easy for me.
It has stronger modified front tie bars, MEF adjustable TCA's and spherical bearing top mounts. And yep I dont run any ARB's front or rear. Car handles like its on rails and you can ask anyone who has driven it for confirmation.
Old Feb 20, 2005 | 10:52 AM
MEF's Avatar
MEF
Former Sponsor
Certainly I can get them done much quicker for those that arn't desperate to run an arb, they will be the first ones produced. After that it will depend upon the availability of a suitable bar, secondhand S1 arb's being the most likely contender or maybe the RS1600i one.
Martin
Old Feb 20, 2005 | 10:58 AM
Blunt's Avatar
Blunt
NutsRUS /Mef
ill order 1 without then please i guess i dont need to change anything to run without 1
Old Feb 28, 2005 | 08:09 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
id be very interested
Old Feb 28, 2005 | 08:39 PM
Westy's Avatar
Westy
definately interested in this
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
