Guys help plz
Old Dec 1, 2010 | 02:43 PM
finesse1.3's Avatar
finesse1.3
Default Guys help plz
hey guys i need a bit of help my fiesta mk5 1.3 heating is crap changed the thermostat and the heater valve and still it goes warm and cold took car for a long run and got home and undid the water bottle top and it wasnt hot just warm and ideas wat can be the problem
cheers dan
Old Dec 1, 2010 | 02:58 PM
RichieST's Avatar
RichieST
gunked up heater matrix or maybe blocked with ice? Has it got plenty of anti freeze in it?
Old Dec 1, 2010 | 03:58 PM
martysmartie's Avatar
martysmartie
You should not be able to undo the header tank when hot (Without being scalded anyway) When was the last time the coolant was changed? If uncertain then you want to be flushing and changing, especially due to the weather conditions now upon us!
I guess it does not overheat at all?
Martin
Old Dec 1, 2010 | 10:06 PM
finesse1.3's Avatar
finesse1.3
thanks guys but iv ran the car disconnected the return hose to the header tank and let it run out and did it a few times as the water was a orange colour we seem to think it is the heating system behind the dash instead maybe blocked with crap etc ....... it will boil but only if u leave it for like 15 mins running on tick over then the fan kicks in lol the coolant is renewed everytime i drop the water and iv done it 4 times in the last month lol but still no heating
Old Dec 2, 2010 | 09:33 AM
martysmartie
You can flush the heater matrix then?
Martin
Old Dec 2, 2010 | 09:50 AM
You could try some wynns rad flush, just leave it in for 200 miles, that's what I do prior to any change of coolant, all the crap in the system will form as a congealed mass in the expansion tank which will of course then need cleaning out, but if anything is going to work this will, failing that undo matrix and leave the matrix/pipes filled with strong bleach overnight.
Old Dec 2, 2010 | 09:52 AM
finesse1.3's Avatar
finesse1.3
it cant be the heater matrix coz the water is running around the engine and when you turn the dial in the car it goes to cold when turned to cold and warm ish wen to hot :S
dan
Old Dec 2, 2010 | 10:05 AM
RichieST's Avatar
RichieST
What does the temperature gauge on the dash read?
Old Dec 2, 2010 | 11:35 AM
martysmartie
dan
Yes the exact thing a blocked heater matrix would do? The rest of the cooling system is independant.
Martin
Old Dec 2, 2010 | 04:14 PM
finesse1.3's Avatar
finesse1.3
Thanks guys done the job now it was a blocked heater matrix it was full of like a orange horrible colour gunk got heat from it now but i will be dropping the water againa and making sure it is perfect ...... the car aint got a temperature gauge its the black dials with no rev counter its a pain in the arse lol do you know if i can fit a rev counter and where would it connect 2
Old Dec 2, 2010 | 06:06 PM
RichieST's Avatar
RichieST
Before you drain the coolant again, run some rad flush through it, as that will help shift any stubborn deposits. Make sure you use the correct quantity of antifreeze too, as it contains a rust inhibitor which will stop it sludging up again in the future.
Old Dec 2, 2010 | 06:09 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Yes you can!
Old Dec 5, 2010 | 10:10 AM
martysmartie
Originally Posted by zetec-Sam
Yes you can!
If you undo very slowly you can to release the pressure, but it's not advisable, pretty pointless post as you don't have anything constructive to say!
On another note glad I could help and it's sorted.
Martin
Old Dec 5, 2010 | 12:50 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
ROFL! Says the person giving totally wrong and inaccurate information!
Old Dec 5, 2010 | 03:59 PM
martysmartie
LOL, no YOUR the gave the DANGEROUS and inaccurate information, clearly you don't know anything!
Martin
Old Dec 5, 2010 | 04:07 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
You said that you can't remove a header tank cap without getting scalded, when everyone knows, aslong as you're careful, you can.
Fool.
Old Dec 5, 2010 | 04:20 PM
martysmartie
Yes and he undone normally and nothing happened which lead me onto say you should not be able to undo (Without being scalded) which is FACT, You are the fool for coming on here and saying it can be done is, not that the OP listened anyway but being pedantic yes you can do it if you release the pressure first, it's still a stupid thing to do even so and is why Haynes etc have warnings stipulating this.
Martin
Old Dec 5, 2010 | 04:28 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
You were wrong, stop digging, and going back on yourself. Boring!
Old Dec 5, 2010 | 04:36 PM
martysmartie
"You should not being able to remove the cap when hot without being scalded" is right and I'm not going back on myself, your the tool who jumps on threads with nothing constructive to say, at the end of the day I knew the answer to the problem YOU didn't whilst giving dangerous advise in the process.
I am not going to back down from this and the more attention it gets the more foolish I am going to make you look when more people start looking at this.
Martin
Old Dec 5, 2010 | 05:45 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Martin
Lol, you couldn't make me look foolish if you tried, your poor grammar makes you look foolish though.
Dry your eyes though mate, no need to cry that you were wrong at first.
Old Dec 5, 2010 | 06:09 PM
martysmartie
I spelt being instead of be, wow! By looking at your posts amongst the spelling mistakes you have made the grammar you use is not in even in the English dictionary, so talk about the pot calling the kettle black, which just about sums up your intelligence really, I have to much to do than go through perfecting my spelling when replying to you.
Don't try and change the subject, the subject in question is removing radiator/expansion tank caps on a hot engine, something you think is good practice!
Crying haha I don't think so, I have been on here much longer than you, I have nothing to prove to people, a fair bunch people know me on here for who I am, and unlike you have something to back my knowledge up with, you on the other hand have been here five minutes and try and nit pick peoples posts as you have nothing better to say!
Martin
Old Dec 5, 2010 | 06:13 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Martin
Because this is a perfect example of exemplary use of the English language.
I love winding up people when I'm bored, makes me laugh how worked up people get over the internet.
Old Dec 5, 2010 | 06:20 PM
martysmartie
I am not getting wound up, I could say the same with you replying, but what does annoy me is people who give dangerous information then try and skate round it when corrected!
BTW thats also extremely sad if your have to resort to "Wind people" up on the internet to get your kicks!
Martin
Old Dec 5, 2010 | 06:22 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
BTW thats also extremely sad if your having to resort to "Wind people" up on the internet to get your kicks!
Martin
I haven't skated round anything, you said it couldn't be done, when everyone knows that it can...
See you're still getting your knickers in a twist though.
Old Dec 5, 2010 | 06:35 PM
martysmartie
Read what the OP said about being able to remove when hot and my response, "You should not be able to remove the cap when hot without being scaled" This is a FACT and there is no debate!
However as I have said and as you know it can be done by gently releasing the pressure and BEING careful I.E not simply removing the cap, even so it still isn't good practice.
Your comment "Yes you can" suggests you are arguing against my valid point to which I have responded!
Martin
Fiddy
21
Sep 29, 2015 06:10 PM
oldskooldanrst
Sep 27, 2015 04:02 PM
`spotty
Sep 25, 2015 11:41 PM
davidfordrs
Sep 21, 2015 04:23 AM
Rizlablue
Sep 6, 2015 09:58 AM
