zinc plating guru's
Old Nov 30, 2010 | 08:47 PM
M K's Avatar
M K
Default zinc plating guru's
could these blades & bolts be zinc plated? would the bolts have to all be shot blasted first as they would be a pain to blast being so small
thanks
Marc
Old Nov 30, 2010 | 08:51 PM
JamesR1's Avatar
JamesR1
Anybody for a brew?
dont see why not, take it there all steel? i had a load done admitabley not that small tho.
Old Nov 30, 2010 | 09:23 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
Hi Marc
I usually blast everything first then quickly go over the parts with the wire wheel to get them smooth.
If you left them blasted, the zinc would be dull and more of a pale yellow due to the course of the part.
This also happens when the metal is very badly pitted because you cant get it smooth enough.
If you run them over the wire wheel this will smooth them out and make the part come out a perfectly deep yellow.
All depends how good the mix is too
Hope this helps
CheeRS
Chris
Old Nov 30, 2010 | 09:24 PM
M K's Avatar
M K
do you do this sort of thing chris?
bobsworth
77
Mar 24, 2016 09:30 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
