PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Concours d'élégance. (https://passionford.com/forum/concours-d-l-gance-45/)
-   -   zinc plating guru's (https://passionford.com/forum/concours-d-l-gance/375459-zinc-plating-gurus.html)
M K Nov 30, 2010 08:47 PM
zinc plating guru's
could these blades & bolts be zinc plated? would the bolts have to all be shot blasted first as they would be a pain to blast being so small
http://img.photobucket.com/albums/v1...O/PICT0022.jpg
http://img.photobucket.com/albums/v1...O/PICT0024.jpg
thanks
Marc
JamesR1 Nov 30, 2010 08:51 PM
dont see why not, take it there all steel? i had a load done admitabley not that small tho.
Chris Latham Nov 30, 2010 09:23 PM
Hi Marc
I usually blast everything first then quickly go over the parts with the wire wheel to get them smooth.
If you left them blasted, the zinc would be dull and more of a pale yellow due to the course of the part.
This also happens when the metal is very badly pitted because you cant get it smooth enough.
If you run them over the wire wheel this will smooth them out and make the part come out a perfectly deep yellow.
All depends how good the mix is too :top::top:
Hope this helps
CheeRS
Chris
M K Nov 30, 2010 09:24 PM
do you do this sort of thing chris?
© 2026 MH Sub I, LLC dba Internet Brands
