xr2 front panel
Old Nov 29, 2010 | 03:02 PM
oldscoolmk2's Avatar
oldscoolmk2
Default xr2 front panel
Hi there, have just relised after stripping my mk2 that the original inner front panel is missing and a replacement front panel had been welded to the lower x-member. can anyone shed some light on how it was wen it rolled out the factory- i assume the front panel was spot welded along the bottom to the inner panel? should i go down this route or weld straight to the x member after putting a repair section on the bottom?
any help would be great
Dan
Old Feb 3, 2011 | 10:40 PM
asimmo74's Avatar
asimmo74
I've replaced a couple of front panels and cross members on mk2's. The front panel should be spot welded along the lower edge of the panel under the cross memeber. If I remember correctly that narrow piece under the cross member is part of the cross member assembly (don't know if you can get a repair panel instead of a complete cross member?).
Need to replace my own front panel so my memory will be refrshed in the not too distant future!
Old Feb 3, 2011 | 10:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above, done one a couple of years back, the crossmember has the curved bit on it then spot weld the front panel to that.
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
gavt123
Sep 5, 2015 10:03 AM
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
