Leak problem
Old Nov 29, 2010 | 11:45 AM
fisher09's Avatar
fisher09
Default Leak problem
Muppet forgot to put de icer in the water, eventually de frosted it all and so on, but found major leaks within the car. It is loosing water from the radiator reservoir.
What's causing this ?
Old Nov 29, 2010 | 11:54 AM
liam-rst's Avatar
liam-rst
shit happens
u wanna hope its not a cracked block mate, how cold was it where u are last night?
fisher09's Avatar
fisher09
Erm it's been around the 0 mark... I guess a crack block would cause that then ?
The car was ticking over okay, didn't have any unexpected sounds..
Old Nov 29, 2010 | 11:59 AM
liam-rst's Avatar
liam-rst
shit happens
if the block is cracked u will only loose water, wont affect the runnin til it overheats, what car is it on?
Old Nov 29, 2010 | 12:03 PM
mr_joe0606's Avatar
mr_joe0606
If block is cracked y is it wet inside the car. I would suspect heater matrix has split.
stevo123's Avatar
stevo123
I am guessing a heater matrix leak with it being in that area, assuming the matrix is in the same place as the mk3/4 escort.
Quick fix is to join the 2 pipes that run from nthe engine bay through the bulkhead, this will in effect isolate the matrix from the cooling system but you will be blooming cold!
PS looks like your coolant is rusty and has no/very little antifreeze in it, you are asking for a popped core plug/cracked block at the worse. Best drain the rad/engine untilyou get round to fixing it or the weather picks up.
Old Nov 29, 2010 | 12:05 PM
mr_joe0606's Avatar
mr_joe0606
To quick for you stevo lol
Old Nov 29, 2010 | 12:08 PM
fisher09's Avatar
fisher09
It's a mk3 escort estate
Old Nov 29, 2010 | 12:19 PM
fisher09's Avatar
fisher09
Thanks for the help !
Old Nov 29, 2010 | 12:20 PM
liam-rst's Avatar
liam-rst
shit happens
i must have missed that bit lol, its gotta have got colder than 0 to freeze the matrix inside the car tho
Old Nov 29, 2010 | 12:36 PM
martysmartie's Avatar
martysmartie
As been said check the heater matrix as could be this but hopefully it's one of the hoses instead.
Martin
Old Nov 29, 2010 | 07:02 PM
fisher09's Avatar
fisher09
What pipes can i disconnect ? and what shall i do with them to bypass the problem ?
Old Nov 29, 2010 | 07:22 PM
wayne dowling's Avatar
wayne dowling
Disconect the pipes that go on to the heater matrix and join them with a piece of 15mm copper pipe
timsrs
Nov 13, 2018 11:48 AM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
