Crankshaft
Old Nov 25, 2010 | 12:11 PM
Criscsw's Avatar
Criscsw
Cosworth passionate
Default Crankshaft
Hi guys....i've a question for you:
What's the best crankshaft for our YB Cosworth?!
Farndon?! Arrow Precision?! What else?!
I'm interesting for a Farndon 84 mm, with Farncon rods 125 mm.....ar they ok?! I don't know...
Please, help me!!
Old Nov 25, 2010 | 12:21 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
what power are you going for ,
as ive heard the standard one is good for 600 hp ,
it was over engineerd by cosworth in the beginning ,
unless going for huge power swapping a crank is unessacary .....
Old Nov 25, 2010 | 12:28 PM
Criscsw's Avatar
Criscsw
Cosworth passionate
I will use the alloy aluminum bloc Cosworth USA, with 8 inj, 4 throttle Jenvey 45 mm, GT3076R, WRC long stud and many more.....
I'm so interest for try this crankshaft!!!
P.S. Farndon was engineered at the beginning...or the standard crank?!
Old Nov 25, 2010 | 01:04 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I would personally go for an arrow crank as I know of too many people who have had harmonic problems with farndon cranks.
If you PM a user on here called "steveboyslim" thats a guy called Steve Milton who does a lot of work with Arrow particuarly with ford and vauxhall engines, and may well be able to get you a discount on your crank, thats who I bought my Vauxhall C20XE Arrow crank through and it was quite a few hundred pounds under retail money.
I would go for the arrow rods as well, again through steve if he is prepared to help you out like he did me.
Old Nov 25, 2010 | 05:45 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Please, help me!!
I would go for longer rods than that, why not change your pistons and go for rods around 133mm long?
Old Nov 25, 2010 | 08:06 PM
Criscsw's Avatar
Criscsw
Cosworth passionate
Martin.....do you think that an Arrow crankshaft 84 mm, with alluminum alloy block 91 mm (+ 10 mm deck height) and Arrow con rods 133 mm for stroker kit, is always better?!
Or, for example, is always better an Arrow crankshaft 88 mm, with alliminum alloy block 91 mm (+ 10 mm deck height) and Arrow con rods 133 mm?!
I'm trying some tests, and an Arrow crankshaft 82 mm, with alluminum alloy block 90.8 mm (+ 10 mm deck height) and Arrow con rods 133 mm for stroker kit...is a great solutions!!!
I want to run very high, above 8000rpm lol!
The head is a touring-car spec, with BD16, double valve spring isky, big valves (+1 mm), and full ported/machined head....8500 rpm and above ya!
jessie_rs
62
Aug 6, 2019 09:27 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
foreigneRS
Technical essay Archives
Jul 20, 2004 11:31 AM
foreigneRS
Jul 20, 2004 11:19 AM
foreigneRS
Jul 20, 2004 11:06 AM
