WINMX
i think you will have to let the application by forwarding you ports (port forwarding)
some one who's more up on this im sure will tell you if im right and how to do this
wheres jim when you need him?
Originally Posted by xpackcapri
what firewall are you using?
you need to look at winmx's configuration and see what TCP and UDP ports it uses, these then need 2 be forwarded in the firewalls settings.
We run off a general server...............I'm not gifted in the IT department!
SS1
Sep 23, 2005 11:39 PM
