Cosworth oil seperator
Old Nov 20, 2010 | 12:28 PM
A.J.'s Avatar
A.J.
Default Cosworth oil seperator
I am fitting an oil breather seperator to my 4x4 cosworth, however i dont want to drill the cam cover, can i plumb the 2 breather pipes to either side of the block ? 1 pipe to the standard breather removing the kidney seperator on the inlet side, and the 2nd pipe to where the bung will be removed on the exhaust side. I would then like to use the drain where the bottom of the standard pipe from original kidney seperator goes to the sump to return the oil from the new seperator drain. what do you guys think, is this ok
Old Nov 20, 2010 | 12:39 PM
JamesH's Avatar
JamesH
https://passionford.com/forum/techni...er-system.html
Old Nov 20, 2010 | 12:51 PM
A.J.'s Avatar
A.J.
That does'nt really tell me if I can or cannot use the original drain to the sump from standard kidney
Old Nov 20, 2010 | 01:17 PM
JamesH's Avatar
JamesH
You need to breathe from the kidney, and the only drain direct to the sump as standard is for the turbo oil drain, on the other side of the engine
Old Nov 20, 2010 | 02:08 PM
A.J.'s Avatar
A.J.
Whats this pipe under kidney to sump for then ?
Old Nov 20, 2010 | 02:40 PM
JamesH's Avatar
JamesH
Most breathe from the kidney and return to the other side if they don't have a direct fitting to the sump
Old Nov 20, 2010 | 02:55 PM
THE RADMAN's Avatar
THE RADMAN
yes.spot on
Old Nov 20, 2010 | 02:59 PM
A.J.'s Avatar
A.J.
Going back to original question mate, will it work the way i want to do it or is it the wrong way to go about it
Old Nov 20, 2010 | 05:08 PM
A.J.'s Avatar
A.J.
Smile
thanks radman
Old Nov 20, 2010 | 10:18 PM
THE RADMAN's Avatar
THE RADMAN
no problems,thats the proper way to do it as the exhaust side one is under positive pressure so really acts as another breather instead of a drain
Old Nov 21, 2010 | 06:58 AM
The Youth.'s Avatar
The Youth.
Presume James hasn't seen a 4wd sump hence not knowing about the extra drain under the kidney box
The only issue with using this drain from the separator is the bore size, I'm told it's not big enough and under heavy breathing the separator could overflow, IMO the engine would have to he well worn fir that too happen.
I it's fine to breath from both sides of the block, I'm am doing this during my engine build on my race car
Steve
Old Nov 21, 2010 | 09:39 AM
A.J.'s Avatar
A.J.
Are we agreed that I can use a bailey breather to plumb it the way I want to ? Also can I use the large vent pipe on the underneath of the breather to plumb straight back to air box as mine has standard air box ?
Old Nov 21, 2010 | 09:44 AM
The Youth.'s Avatar
The Youth.
on a road car just let the big vent pipe vent to atmosphere down near the ARB, you don't want your engine breathing all them nasty hot oil fumes
steve
Old Nov 21, 2010 | 09:49 AM
A.J.'s Avatar
A.J.
Thanks youth, you would be losing alot of oil from engine if the breather were to overflow, did'nt realise as much would pass through seperator !! is a bailey ok for the job ? who sells adaptors for both sides of block ?
Old Nov 22, 2010 | 10:09 AM
The Youth.'s Avatar
The Youth.
a bailey seperator is fine for the job, I am using one myself on my car.
the adapters are on ebay to vent from both sides, on the turbo side it's threaded and on the inlet side it pushes in
steve
Old Nov 23, 2010 | 11:00 AM
A.J.'s Avatar
A.J.
Nice one, thanks steve
Oct 9, 2015 07:38 PM
Cosnada
Sep 2, 2015 01:10 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
Aug 14, 2015 07:29 AM
