Escort front windscreen
Old Nov 19, 2010 | 03:43 PM
hullguy1974's Avatar
hullguy1974
Default Escort front windscreen
Hi there i have just obtained a 97 escort ghia which has heated front windscreen the screen looks fine but has no power going to the screen when you press the switch on the dashboard there is no light that comes on but the rear screen works fine. and the bulb lights up on the rear screen button which is combined with the front screen.
I have ruled out that it may just be the bulb gone in the switch as i tried leaving it on but there was no response to the windscreen as the ice remained in place. I have checked the fuse and the fuse looks fine i havent checked the relay as yet but have been told its a power fault if no light works on the switch. Has anyone come across this problem if so any help would be much appreciated
Old Nov 19, 2010 | 03:49 PM
martysmartie's Avatar
martysmartie
First off you do know that it won't work unless the engine is running?
If so then check you have power to the switch with the engine running.
Martin
Old Nov 20, 2010 | 05:14 PM
dangerousbrian's Avatar
dangerousbrian
try the earth wires from the screen..off the top of my head they are on the inner wing..it may have had a new screen in at some point, and the bolts are prone to snapping when trying to remove them
Vincereese
Jun 1, 2023 09:14 AM
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
