Ford Range This section is for other models in the Ford range.
twin 40's
Old Nov 18, 2010 | 07:17 PM
gavt123's Avatar
gavt123
Default twin 40's
hello all
my brother has just brought a mk4 escort 1.6gl, He has a set of twin 40's that he is thinking about fitting onto the car so can someone post a list of what he will need for the job in hand please?
Thanks
Gav
Old Nov 18, 2010 | 08:52 PM
F99 REV's Avatar
F99 REV
A spanner!
Old Nov 18, 2010 | 08:59 PM
gavt123's Avatar
gavt123
whats one of them?
and what is it used for?
Old Nov 19, 2010 | 08:36 AM
javierant3's Avatar
javierant3
To fit the 40`s you need the inlet manifold and electric fuel pump.You need to blank where the old pump was with a plate. Also you will need a throttle cable kit to operate them.
Old Nov 19, 2010 | 08:51 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Then you will need to buy lots of jets and take it to a rolling road to get the optimum performance from the engine
Old Nov 19, 2010 | 06:33 PM
gavt123's Avatar
gavt123
thanks chaps he has got a throttle cable is it a specific one for the escort or are they all the same?
thanks again
Gav
Old Nov 20, 2010 | 04:50 PM
crumpet's Avatar
crumpet
you can use the escort one pal, have to be diy, as long as youve got the gaskets, inlet manifold youl be ok, do you know what car they came off? Bogg bros up north will sort the tune out for £80 on the rollers, the carbs are very simple to fit though, ideally youl need a different maniold and a decent exhaust and cam to make the most of them though
cheers
Old Nov 20, 2010 | 04:55 PM
gavt123's Avatar
gavt123
there bolted onto a cav 2.0ltr 8v at the moment.
he has got a straight through powerflow exhaust system going on once we get round to it
Old Nov 20, 2010 | 04:58 PM
crumpet's Avatar
crumpet
sell me that cav engine with the carbs on it il put it in a nova!
it should run ok with them setup as they are tbf as long as theyre running perfect on the cav.
On monday ring boggbro's pal, they will be able to sort you out with setup, they make the inlet manifolds too
Old Nov 20, 2010 | 05:06 PM
gavt123's Avatar
gavt123
he never got it running wasnt getting a spark then he got the escort so he is breaking the corsa, apparently his mate rebuilt the engine so he will be selling that but he wants the carbs im afraid lol.
have you got there number please mate because he needs to get the inlet manifold
Old Nov 20, 2010 | 05:13 PM
crumpet's Avatar
crumpet
01944 738234 there ye go pal
Old Nov 20, 2010 | 05:14 PM
gavt123's Avatar
gavt123
lovely thanks mate
Old Nov 21, 2010 | 02:47 AM
bigryrs's Avatar
bigryrs
RSHoleinator
Every month lol
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
