Coolant Pipework ?
Old Nov 16, 2010 | 02:59 PM
Hoogi's Avatar
Hoogi
Default Coolant Pipework ?
Hope someone out there can advise ?
Where do the following go too or come from..........I'm not running a Heater as it's a Track Car.
1) The inlet/outlet on a 4WD Water Pump - it sits at about 8o'clock position and has an ID of about 8-10mm.
2) The very small inlet/oulet on a 4WD Thermostat Housing - it sits at the top exits on the left-hand side at about the 9o'clock position and has an ID of about 4mm.......can I loose this/block it off ?
3) And finally - I have three returns/outlets to my Header Tank:-
One is from the top of my Swirl Pot (no problem), one comes back to the Header Tank via my Turbo Cooler. But where is the larger bore outlet supposed to feed ?
So many questions, so I do appologise
Old Nov 16, 2010 | 04:03 PM
Any piccies, the heater output from the water pump can be blocked off as can the head stub where the heater outlet end sup.
Old Nov 19, 2010 | 02:33 PM
Hoogi's Avatar
Hoogi
Hi Tabetha,
The cars away having a rewire at the moment so unfortunately no pics to help.
But thanks for the input.........
So that's the Water Pump outlet not required - but what goes to the the water thermostat at the back top right-hand side of the block, where the blue plug is ?
I've done way with the oil heater section that usually feeds from there to the oil filter as I was going to run a small oil cooler
Again, any help would be fantastic.
Old Nov 22, 2010 | 01:41 PM
Hoogi's Avatar
Hoogi
Anybody else out there running a Cosworth powered Track Car without a heater ????
Cheers again
Old Nov 22, 2010 | 02:37 PM
Originally Posted by Hoogi
Hi Tabetha,
That can also be blocked off.
TPM961
Jan 15, 2018 10:50 AM
Fudgey
21
Sep 30, 2015 06:19 PM
Botts
Sep 22, 2015 02:04 PM
