are Xr4x4s got the same bits as cosworth?
Nov 15, 2010 | 02:46 PM
500bhp Cosworth in making
are the xr4x4 bits same as 4x4 cosworth (sierra)
Engine Cradle
Gearbox
Steering Rack
Nov 15, 2010 | 02:48 PM
think the steering rack ends are 10mm longer each side,the bolt pattern on the bellhousing is different and im unsure about the cradle,but i think its the same.
Nov 15, 2010 | 02:49 PM
Quote:
Originally Posted by
155lee
2.0 XR4x4 bellhousing is the same
Nov 15, 2010 | 02:54 PM
Nov 15, 2010 | 02:59 PM
natehall
since there were very few of them compared to 2.9's i based my comment on that!
Nov 15, 2010 | 03:23 PM
gearbox ratios and first motion shaft are different also, front prop is different
Nov 15, 2010 | 05:52 PM
only the crossmember is the same
Nov 15, 2010 | 05:58 PM
Roosie, I posted on your wanted thread. Look at my "Various updated 4x4 Cossie bits" post for most the bits you need
Nov 15, 2010 | 06:53 PM
Resident Wrestling Legend
you can use the crossmember, engine mounts, steering rack, props, diffs, rear shafts if you have the 2.9
if you have the 2.0 then you can use the gearbox, but not the diffs as they are different ratio's
Nov 15, 2010 | 07:34 PM
i take it you can use front shafts of the 2.9?
Nov 15, 2010 | 07:41 PM
the front non cossie shafts are about an inch longer so they bind up in their stops
the cv's are the same though
Nov 15, 2010 | 08:53 PM
so would be better as i have camber
Nov 15, 2010 | 09:36 PM
Quite a few people have fitted the longer xr shafts to lowered cossies due to the camber and problems when on full lock
Nov 15, 2010 | 10:57 PM
parts that are the same are
engine cradle
engine mounts
front and rear diff
rear driveshafts
front driveshafts are longer but will work fine
front and rear prop are the same(only early 2.9 and 2.8 used a skinny front prop)
rear beam will be ok, only difference is hubs are taller and bushes( fine if you go cossie hubs and poly bushes)
abs pump is the same
JoeyBoyden
Jan 4, 2024 02:36 PM
Oct 9, 2015 07:38 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
