More problems!!!!
Old Nov 13, 2010 | 08:34 PM
CVHman's Avatar
CVHman
Default More problems!!!!
Took the MK4 estate for a spin and all is not good,,it shakes violently at anything above 20 MPH,so much so the the bonnet,steering column and dash actually shake,,,got it up on stands and checked both wheels for bad buckling but all seems good,,there is also a horribly loud humming noise coming from up front that seems to go out of it when turning left(but not right),,,,,it seems to me that it is a bearing but would this also cause the shaking.
Just to add,,,its not balancing,far worse than that.
Thanks in advance for any help,,
Old Nov 14, 2010 | 10:58 AM
Check the universal joints on the driveshafts.
Old Nov 14, 2010 | 11:03 AM
mr_joe0606's Avatar
mr_joe0606
same sort off thing happened to me and it was a bearing
Old Nov 14, 2010 | 11:55 AM
CVHman's Avatar
CVHman
Tabatha!
Thanks mate,,I will have a look at them,
Mr joe0606
I'm hoping its just the bearings,I will swap out the two of them and keep my fingers crossed.
Thanks guys!!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
