erst no fule to injectors, heelp plz !
Old Nov 12, 2010 | 03:13 PM
1428levi's Avatar
1428levi
Default erst no fule to injectors, heelp plz !
my escort was running boosting fine then jus cut out as if no petrol, gotr her home and checked metering unit am gettin pressure out the filter and got pressure out the return ect but no fuel coming out 4 injectors on the head of the metering init, when i push the flap down get some feul out but only runs for a couple of second then wont start again, so is only running briefly on the cold start, the pump is wired direct to battery have checked for vacuum leaks ect jus cant understand why hav no fuel all of a sudden , can any one help
Old Nov 12, 2010 | 03:55 PM
boothy's Avatar
boothy
Poss air in the pipes mate?
Someone else will no doubt let you know whats what
Old Nov 12, 2010 | 05:01 PM
fatmike's Avatar
fatmike
more than likaly to be the metering head is fobard had a similer prob and it was that part
Old Nov 12, 2010 | 05:18 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
sounds like metering head to me too.
Old Nov 12, 2010 | 05:28 PM
1428levi's Avatar
1428levi
can the meterin head be changed or would i have to replace the whole part as only replaced it 6 months ago could there be an air buble in the head it self but then wen i push the flap i get a rush of fuel so its as if the flap is not opening on its own ??
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
