ecu help
Old Nov 9, 2010 | 09:08 PM
mikeyb_699's Avatar
mikeyb_699
Default ecu help
Hi guys
Can any one help with this iv got a l6 ecu and have just installed a lambda sensor can I connect the single out to pin 2 to create a closed loop circuit
Thanks mike
Old Nov 9, 2010 | 09:12 PM
martysmartie's Avatar
martysmartie
It would have to have the software as well, not sure if the hardware on L6 is compatiable even, L8/P8 certainly is. MSD will probably reply soon will a definate answer.
Martin
Old Nov 10, 2010 | 12:56 PM
mikeyb_699's Avatar
mikeyb_699
is ist possible to put a L8 ecu on a L6 loom
Old Nov 10, 2010 | 01:29 PM
martysmartie
Yes but you need to revert the two wires on the TPS as they read the opposite of each other, I think that is all.
Martin
Old Nov 10, 2010 | 01:33 PM
mikeyb_699's Avatar
mikeyb_699
can I still use the same 2wd TPS
James @ M Developments.'s Avatar
L6 will not run closed loop.
L8/P8 will run on a 2wd loom, just swap the TPS to a PF09 and revert the two outer wires.
The lambda sensor needs a live, earth, and the signal runs to pin 2.
Even if you use a L8/P8 the software will need to be closed loop enabled for it to work
Old Nov 10, 2010 | 01:36 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
As per what James says, you cant just go adding random extra sensors and hope your ecu will know what to do with them
Old Nov 10, 2010 | 01:39 PM
mikeyb_699's Avatar
mikeyb_699
If Im buying a second hand ecu how will i know if it is closed loop enabled
you will need to know whats on the chip,
any L8 CAN do closed loop,
P8s should generally always be closed loop as they are adaptive, exceptions to the rule are out there that have had the closed loop disabled for various reasons though.
Old Nov 10, 2010 | 01:42 PM
mikeyb_699's Avatar
mikeyb_699
No one is just adding random sensor im using the lambda sensor on a air/fuel ratio gauge at the moment and someone mentioned a close loop so im finding out from the people that know best you lot.
Old Nov 10, 2010 | 01:43 PM
mikeyb_699's Avatar
mikeyb_699
Thanks for all the help .
Old Nov 10, 2010 | 01:44 PM
what sort of spec are you intending to run?
Old Nov 10, 2010 | 01:50 PM
martysmartie
As I said from the start you need the CL software, the hardware needs to be compatible of supporting it, therefore you will need to have a CL chip (I think MSD can do this if you send the chip to them).
You need a L8, it will only be 'CL enabled' if the chip inside is, which brings me nicely onto saying that with a L8 you cannot use your chip you have at the moment although it is possible to convert them.
Martin
Old Nov 10, 2010 | 01:53 PM
mikeyb_699's Avatar
mikeyb_699
Tell you the truth im using the 2wd cosworth management on a different non ford engine.
but using throttle body, dizzy, turbo,injectors, inter cooler, loom and ecu. Its a 1.5lt block and only want 250bhp
a L6 chip will run in a L8 if you take the baby board out,
This is why we have had arguments with various RS Breakers who sell L8s without the board, because without the board its simply a L6 with a few mods lol.
Old Nov 10, 2010 | 01:58 PM
martysmartie
So I guess the 'baby board' gives more memory allowing extra features to be utilized? I know the L8 chips are double the size of the L6.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
