heating in my car does not work
Old Nov 9, 2010 | 05:53 PM
edzybo's Avatar
edzybo
Default heating in my car does not work
hi can some one please help me, i have a ford focus 3dr 2000 model which i think its the mk1, my heater inside the car does not work work at all numbers 1.2.3.4 when selected nothing comes on normally u would hear the heater fan, can some one please tell me what this could be n what i need to check and buy, and also if you no prices
many thanks
Old Nov 9, 2010 | 06:39 PM
cabriolet's Avatar
cabriolet
go down the page from your post there are two more discussions on this problem
Old Nov 9, 2010 | 07:42 PM
martysmartie's Avatar
martysmartie
Have you checked the fuse? The fact you have nothing shows there to be a power supply problem or the motor itself has packed up.
Martin
Old Nov 14, 2010 | 02:45 AM
edzybo's Avatar
edzybo
ive checked the fuse and the fuse was blown so i replaced the fuse with a new 1 but as soon as i fit the new 1 and turn the ignition on for the fan to come on the fuse blows up could that just be because the resistor is fckt
Old Nov 14, 2010 | 10:51 AM
It could be the motor is jammed, or a dead short, unplug the motor and replace the fuse again, don't be tempted to up the rating of the fuse, this can cause fires and destroy your car!
It could have lost the earth to the motor, ie broken wire, unplug motor and check output at the connector that goes on the motor.
I've known one over the years where the owner always ran with no pollen filter, eventually enough crap found it's way in the heater to jam the motor.
Old Nov 14, 2010 | 11:40 AM
martysmartie
As said if it's blown again it indicates an electrical problem, motors are not un common for siezing as water can get inside. I would be checking this next.
Martin
track.focus'd
Aug 12, 2015 05:53 PM
Lee Reynolds
85
Aug 10, 2015 05:56 PM
