Sierra DOHC 8v Turbo Selection Help
Old Nov 8, 2010 | 10:03 PM
mhs's Avatar
mhs
Default Sierra DOHC 8v Turbo Selection Help
hi all
Max RPM 7000
Which one should I choose for Sierra 2.0 DOHC 8v ,GT28R,GT30R,GT35R
Old Nov 9, 2010 | 05:33 AM
chaffe's Avatar
chaffe
Turbocharging Technician
What power level are you going for mate? a t28 will be smaller than the turbo you have already, but maybe you want less lag?
Old Nov 9, 2010 | 05:19 PM
mhs's Avatar
mhs
I want high-TORQ
I use T3/T4 63 A/R, External Wastegate 28 PSI Boost now
3500 7000 rpm range
I would like a big turbo
I want to with a big turbo, low boost ,high-TORQ
Old Nov 10, 2010 | 11:05 AM
chaffe's Avatar
chaffe
Originally Posted by mhs
I want high-TORQ
3500 7000 rpm range
Less than 28psi? the turbo you have is quite large for a 2 litre, i had the same on my 2 litre 8v zvh, was a lot of lagg and no power until 4000 rpm, what is the reason for changing turbo?
Old Nov 10, 2010 | 11:07 AM
chaffe's Avatar
chaffe
A t34 .48 would give you similar power but much more low down torque and drivability. At28 is a bit small IMO, based on a t25 footprint.
Old Nov 10, 2010 | 02:41 PM
mhs's Avatar
mhs
I think with a large turbo- 15 max 20 PSI
Sample : GT30R - 3500 7200 RPM - 15 PSI , may be more of a power
1.6 honda civic uses GT35R
Old Nov 10, 2010 | 02:43 PM
chaffe's Avatar
chaffe
honda revs to 9000 rpm though and the head flows much better, a bigger turbo may not come in till 4500 or even 5000 rpm, then you will loose low down torque and power, and im not sure it will make the power at lower boost even if it is bigger.
Old Nov 10, 2010 | 02:47 PM
mhs's Avatar
mhs
small turbo high revs is not enough (2000 RPM 4500 ends)
Old Nov 10, 2010 | 02:50 PM
chaffe's Avatar
chaffe
lots of boys use them on yb cosworths upto about 350 bhp, how much power are you making? i think the turbo size you have is good
Old Nov 10, 2010 | 03:20 PM
mhs's Avatar
mhs
I love twinky ,I do not want Cosworth yb
target GT3076 ,285 cams 450+HP
Old Nov 10, 2010 | 03:25 PM
chaffe's Avatar
chaffe
i was comparing power outputs of the engine with the .48 turbo
Old Nov 10, 2010 | 03:47 PM
mhs's Avatar
mhs
now I use the turbo T3/T4 inlet 50 ex 63 Comes 3000RPM
not enough over 5800 RPM
I'm looking for a powerful turbo, Up to 5800RPM
http://www.streetfire.net/video/ford...st_2079982.htm
Old Nov 10, 2010 | 04:19 PM
wilky's Avatar
wilky
i'am using a hx35
Old Nov 10, 2010 | 04:50 PM
mhs's Avatar
mhs
Originally Posted by wilky
i'am using a hx35
What is the Turbo Spec ?
What is the rev range
thanks.
Old Nov 11, 2010 | 07:18 AM
chaffe's Avatar
chaffe
holy fuck, thats a fair sized turbo
Old Nov 11, 2010 | 09:07 AM
mhs's Avatar
mhs
I think I will be better ,GT3076 with 20PSI Boost (3500 7200 RPM)
Old Nov 11, 2010 | 03:04 PM
wilky's Avatar
wilky
it's a hybrid hx35 with a smaller turbine should spool it by 4000 rpm . 3 bar of boost if needed i'll run it at 2.4 bar [if i can get it on pump gas]
Old Nov 11, 2010 | 04:38 PM
mhs's Avatar
mhs
what tire you use ,will grip the road problem
I've had 2.bar boost
Old Nov 12, 2010 | 05:39 AM
chaffe's Avatar
chaffe
lol, this is the problem we all face
Old Nov 12, 2010 | 05:28 PM
mhs's Avatar
mhs
Mickey Thompson Performance Tires
Do you have that uses
Old Nov 13, 2010 | 05:14 AM
møffe's Avatar
møffe
285cams on a turbo car. std dohc drives std 244 degrees and 10.5 mm lift.
to get low down power then abaut std degrees and more lift. ive mounted 11.55 lift regrind cams on a NA dohc with out problems.
a dohc are not a rpm engine. but a high tourque engine.
last dohc ive made for a friend made 150NA hp with out ajustment and 200nm.
pullede all the way up to 7000rpm
there are a lot of flow to get in the head.
were are you now with HP?
Old Nov 13, 2010 | 09:12 AM
chaffe's Avatar
chaffe
shangdon linglons
Old Nov 13, 2010 | 07:02 PM
mhs's Avatar
mhs
I use stock cams
Just think of 285 cams
stock cam, stock crank with I use 7000rpm 28PSI boost no problem
Old Nov 13, 2010 | 07:06 PM
rapid3door's Avatar
rapid3door
anyone know a cheap place that does turbo manifolds for dohc sierra engines
Old Nov 13, 2010 | 07:14 PM
mhs's Avatar
mhs
hand made
Matt Baxter
Sep 16, 2015 08:30 PM
tomiii
12
Aug 18, 2015 08:40 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
Adam-M
22
Aug 10, 2015 10:46 AM
