Cosworth cylinder head torque wrench settings ?
Jan 27, 2005 | 03:36 PM
Could one of you helpfull chaps tell me the torque settings for my 3dr
Stage 1 20-25
Stage 2 45-50
Stage 3 ?
Stage 4 ?
thanks
Ricky
Jan 27, 2005 | 08:31 PM
Stage 1 = 20-25nm.
Stage 2 = 45-50nm.
Stage 3 = Rotate further 170degrees to 180 degrees.
thats it.
Jan 29, 2005 | 05:41 PM
Thanks m8
Jan 29, 2005 | 07:56 PM
stage 3 is 90 degrees
stage 4 is a further 90 degrees, all in the correct order
Jan 29, 2005 | 08:49 PM
not according to Ford workshop manual. only 3 stages.
for other than 3dr, torgues are slightly diffirent, but allways must turn in one stage to correct amount of degrees.
Jan 30, 2005 | 08:47 AM
It's right, Ford said first stage 3 90° and stage 4 90 °, but they have corrected that and said later to rotate an only stage 3 at 180 °
Jan 30, 2005 | 11:40 AM
My Ford workshop manual says stg3-90, stg4-90?
Confusing then that.
Jan 30, 2005 | 06:29 PM
Yes it is, but I did go to a formation which was make by Ford France on the cosworth engine and they said we need to correct that. But I think it's not very important...
Jan 30, 2005 | 06:53 PM
Jan 30, 2005 | 08:05 PM
one should allways use latest technical information, and should be allways checked before work.
Feb 1, 2005 | 08:31 PM
cheeRs Glurbs
JoeyBoyden
20
Aug 22, 2015 03:23 PM
turbotrev
Aug 22, 2015 11:41 AM
Aug 14, 2015 07:29 AM
Bobby9779
Aug 11, 2015 06:47 PM
Zoggon
Aug 10, 2015 10:39 AM
30 ,
cosworth ,
cosworthservice ,
cylinder ,
ford ,
head ,
heads ,
manual ,
sapphire ,
settings ,
sierra ,
tension ,
tightening ,
torque ,
torques ,
wrench
