heated front screen
Old Nov 6, 2010 | 03:26 PM
dom1957's Avatar
dom1957
Default heated front screen
hi all new here ,i have a mk 6 fiesta 1.2 zetec ,problem front heated screen use to work but dont now
i had a look at fuse box and diagram ,it shows r3 which looks to me like a relay ,grey.
was told the fuse would be a 30 amp but unsure anyone help
Old Nov 6, 2010 | 05:51 PM
wrcjuha's Avatar
wrcjuha
Hi mate and welcome,
I am new here too really, but I'm sure your thread should be in the general discussion room, as a much better chance of reply in there and people can say hello aswell .
Old Nov 7, 2010 | 12:15 PM
martysmartie's Avatar
martysmartie
Hi,
Not sure on the Fiesta specifically but sure it should be the same, the fuse is 50A on other Fords it's one of the bigger fuses in the engine fuse box. Does the indicator light illuminate with the switch on? Remember the engine has to be running for it to work.
Martin
Old Nov 7, 2010 | 12:21 PM
RichieST's Avatar
RichieST
When you press the button do you hear a click from the fuse box? Check under the scuttle panel where the connections are for the screen. On the focus it isnt uncommon for them to go rusty, so could be worth a look.
Oct 9, 2015 07:38 PM
3drRich
Sep 13, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
C2 MAK
Aug 20, 2015 09:46 PM
