Group A head gaskets YB0611
Fozy,
Forget about the YB0611 - as even with a huge discount it wont be as cheap as the standard late Es Cos gasket: YB1261
These are approx £ 19.00 from PJ Motorsport or your Ford dealer.
Quote Karl Norris:
"The std escos head gasket is YB1261 (the GpA YB0611).
The gaskets are identical in construction with the exception that the the YB1261 has two crimp rings around the oil drains, which helps prevent oil seeping into the gasket around these oil ways.
Power wise both gaskets are suitable for up to 300bhp in std form and 500+ with wire ringing.
The use of either of these gaskets over around 300bhp without wire ringing will result in premature failure as the gasket fire rings gradually get "blown" out making the fire ring oval shaped with eventual failure. Exactly how long it will last is debatable as its dependant on how much on boost driving the engine sees, but expect either of these gaskets at over 350bhp to last less than 10,000miles.
_________________
Best regards,
Karl............Norris Motorsport"
Quote Karl Norris:
_________________
Best regards,
Can anyone confirm if a gasket marked as YB1261 is definitively this later Escort type gasket that we talk about, or whether the earlier gaskets are marked the same (with the same fluid reinforcing rings), but an inferior part with the same part number?
Mc5506
Oct 5, 2015 09:57 PM
