Cast iron welding???
Old Nov 4, 2010 | 07:19 PM
Rs2kturbofizzbomb's Avatar
Rs2kturbofizzbomb
Default Cast iron welding???
I am attempting to weld my erst manifold to my Rs2000 exhaust flange and I have be advised against it as it is cast iron and would be weak..
I have seen it done before with no problems..
Has anyone had cast iron welded in this type of application and had problems??
Old Nov 4, 2010 | 10:03 PM
cabriolet's Avatar
cabriolet
to do it properly powdered iron rods [arc] pre heat weld hot cool naturally if welded normally it nearly always cracks just beyond the weld
Old Nov 5, 2010 | 12:35 AM
COLEYST200's Avatar
COLEYST200
i use this place for all my speshol welding stuff and i no they have welded cast in the past
http://www.bropel.co.uk/
Old Nov 5, 2010 | 12:40 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Good advice, not done it myself but I know people that have and having it very hot when you weld it is key to it working.
Old Nov 5, 2010 | 01:12 AM
botters's Avatar
botters
competant bodger
get it hot to around 200-250 degrees and weld it immediatley then put back in the oven and bring heat down ten degrees every 5 minutes or so until cool or leave to cool by covering it completley in sand, mig welding is fine if done this way but you have to be aware that while cooling it can still crack, usually accompanied by a loud bang lol!
Old Nov 5, 2010 | 01:14 AM
Chip's Avatar
Chip
Do you mean MIG with just a normal mild steel wire, or do you need a wire with higher than normal iron content?
Old Nov 5, 2010 | 01:55 AM
botters's Avatar
botters
competant bodger
ive used mild steel mate not ideal but it works (most of the time!)
Old Nov 5, 2010 | 02:02 AM
Chip's Avatar
Chip
Cool tip!
Old Nov 5, 2010 | 07:02 AM
Even when welded as above it can and most likely will still crack9again), due to thermal shock, made worse with certain designs, but very small cracks can often be ignored.
Old Nov 5, 2010 | 07:07 AM
chaffe's Avatar
chaffe
Turbocharging Technician
it depends on the cast material, cast iron will have more of a tendancy to crack, cast steel (like most manifolds) will be better to weld, i had an erst turbo elbow welded before, for an lambda boss, and it was perfectly fine, would it not be easier to make an adaptor plate or re drill and tap the head for the studs?
Old Nov 6, 2010 | 11:24 AM
zippyobrien's Avatar
zippyobrien
I've done this but with a zetec flange. As said get it really hot. And use some of that anti slayer spray.
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
