connect front lights
Old Nov 4, 2010 | 06:36 PM
alec56connect's Avatar
alec56connect
Default connect front lights
whats the easiest way to paint the insides of the transit connect headlights my mate mentioned baking them 2 loosen them up but im abit nervous bout putting them in the oven!
Old Nov 4, 2010 | 06:51 PM
RichieST's Avatar
RichieST
I've done about 10 sets of different lights now, it's all very well heating them up, but then they are far too hot to handle. Your best bet is to use a heat gun to warm the glue section at a time, nice and hot, just before the plastic starts to melt. then run a blade or a small flat blade screwdriver through the glue. You should then slowly be able to pull them apart.
Does make a huge difference, here's my current car, before and after.
Old Nov 4, 2010 | 10:29 PM
alec56connect
yea that does look the bollox mate whats the best way of spraying them did u sand off all the chrome?
Old Nov 5, 2010 | 01:29 AM
danme1987's Avatar
danme1987
when i did mine i just scuffed all the chrome and then primered but it looked rough so i gave it a couple more layers and then wet and dry'd with 2000 i think it was and was smooooooooooooooth after that. then obv base coat
Old Nov 5, 2010 | 07:19 AM
RichieST's Avatar
RichieST
just give them a rub down with some wet and dry paper to remove the shine and give them a good key, wash with hot soapy water, few coats of primer, rub back with fine wet and dry again, then a few coats of matt black.
Old Nov 5, 2010 | 03:24 PM
alec56connect
so u reckon matt black is the way 2 go? cheers lads ill ave a go when this poxy rain stops
Old Nov 5, 2010 | 03:25 PM
RichieST's Avatar
RichieST
Yes matt black, looks spot on when behind the clear lens. Anything glossy looks a bit too much if you get what I mean!
Old Nov 5, 2010 | 03:35 PM
alec56connect
ha yea true nice 1 mate
Old Nov 5, 2010 | 09:44 PM
mercury grey minter's Avatar
mercury grey minter
Use a heat gun and a blade to cut the lenses out,then scuff the chrome with flatting paper and a few coats of matt black.
Mines looks like this.
Old Nov 6, 2010 | 01:29 AM
alec56connect
im liking the colour coded mirros mate! van looks nice with subtle mods
Old Nov 6, 2010 | 01:30 AM
alec56connect
how have you guys re-sealed ya lenses?
Old Nov 6, 2010 | 09:24 AM
RichieST's Avatar
RichieST
tiger seal
Old Nov 6, 2010 | 10:11 AM
alec56connect
nice 1 lads ill get the pics up soon as i get time
Old Nov 6, 2010 | 01:33 PM
mercury grey minter
Sika-flex bonder
original
Apr 28, 2026 05:20 PM
C2 MAK
Aug 20, 2015 09:46 PM
Sjieter
Aug 5, 2015 09:47 PM
Old ford
Jul 31, 2015 06:50 AM
