speedo problem
Old Nov 1, 2010 | 09:31 PM
MARKYMARKONE's Avatar
MARKYMARKONE
Default speedo problem
hi
my brother has a 1990 s2 turbo which has a strange problem with the speedo, when accelerating the speedo goes up as it should but when you back off or change gear the needle goes up and down like a rev counter.
so far weve changed the cable and tried a different speedo head with no luck, then we took out the speedo drive which was worn so we replaced that with a new one and all was good for a day or 2 and then it starts playing about again, i took the drive out again and its worn this again.
has anybody got any ideas as im lost what to try now
cheers
mark
Old Nov 2, 2010 | 06:00 PM
xrmalin's Avatar
xrmalin
Ive been told before it could be the diff bearings on there way out thus leaveing more room for it to move around and wear out the speedo drive in the box.
Old Nov 2, 2010 | 08:59 PM
stwibs's Avatar
stwibs
shagged gearbox im afraid as above
Old Nov 3, 2010 | 07:28 PM
MARKYMARKONE
thanks guys,
thats what i didnt want to hear, it looks like rebuild time
cheers
mark
DAZZER
Sep 30, 2015 08:43 PM
cossie brad
Sep 29, 2015 02:38 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
