been asked many times, ABS removal slight issue
Old Oct 31, 2010 | 06:20 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default been asked many times, ABS removal slight issue
basically took all my abs shit on the gearbox and binned it,
but i dont wanna take off the rear compensaters, so can i just use my std abs mastercylinder and run 2 pipes from the outlets to the t-pieces on the inner wings?
Hope some as done it this way
Old Oct 31, 2010 | 06:56 PM
Rob_DOHC's Avatar
Rob_DOHC
Pretty sure you can do just that mate, all you do is bypass the modulators.
Rob,
Old Oct 31, 2010 | 06:58 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i took off the everything to do with the abs just left the rear compensaters, the bracket that holds the pipes near th gearbox, that has gone too,
so now i can just run 2 new pipes to the t-pieces and sorted?
Old Oct 31, 2010 | 07:08 PM
Rob_DOHC's Avatar
Rob_DOHC
Should be mate, T-piece on the drivers side feeds the drivers side front and passenger side rear, obviously the opposite for the T-piece on the passenger side.
Rob,
Old Oct 31, 2010 | 07:11 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
ok just that some people say about compensaters to the front or something?
Old Oct 31, 2010 | 07:21 PM
Rob_DOHC's Avatar
Rob_DOHC
Could be mate, tbh im not to sure as im just using a bias valve,
have seen some people using the xr3i compensators at the front but im fairly sure this is because they don't have the rear proportioning valves like the rst,
Rob,
Old Oct 31, 2010 | 07:31 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i see, ok so ill just carry on doing what im doing, and make 2 new pipes from master cylinder to t pieces and keep the rear load compensaters, and all should be well
original
Apr 28, 2026 05:20 PM
Bailes1992
Aug 16, 2015 07:14 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
