Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
rs turbo dead :(
Old Oct 27, 2010 | 06:38 PM
mr noisy's Avatar
mr noisy
Default rs turbo dead :(
Hello all i have a RS turbo mfi which has desided to have a prob it started this morning but was running little ruff then its now died all togeather and has no spark from coil when ignition is off both posative and neg on coil show negative then with ignition on there both posative ??? any ideas guessing a wire prob but is there a idea of wherte to start or some thing to test out inc places to look for a broken/short wire
Old Oct 29, 2010 | 06:38 PM
dave_s2_rst's Avatar
dave_s2_rst
loads of places mate.
Are you defo no getting a spark?
check the green wire has not broken - it runs along the front of the car, under rad and into the back of the rev counter, the other runs to the ecu. Check these feeds.
Does your fuel pump prime when switched on ignition?
Old Oct 29, 2010 | 08:27 PM
mr noisy's Avatar
mr noisy
yes mate the fuel pump was fine its now running but just has a bit of pop and a bang now and again when under load before it comes on boost and also seems little flat b4 it comes on boost so gonna see what the timing is like tomorrow all going well and maybe advance her up a little then turn boost down a little as 24psi seems little to much me thinks LOL
Old Oct 29, 2010 | 08:52 PM
dave_s2_rst
turn that psi down and get it booked in, mine was something silly before it got turned down to 14psi
Old Feb 8, 2011 | 04:10 PM
RstNewbie's Avatar
RstNewbie
Hiya i no this is a late post but did you ever find out what the problem was as mine is doing exactly the same this is my first rs turbo and my first turbo car so i have no clue about psi etc ? :S
Old Feb 8, 2011 | 07:36 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Whats it doing exactly m8??? by the way i am also in torquay up at the willows if ever you need a hand or advice with anything
Old Feb 9, 2011 | 08:33 PM
RstNewbie's Avatar
RstNewbie
That is good to no mate as i have no clue what i'm doing basically it stalled the other day so i called aa out he told me i was getting a weak spark and told me to change the coil (i ordered one) i used the car yesterday for work on the way no problem on the way home 20 mins into the journey it died again and started about 20 mins later then died about 10 mins after that and 5 mins again after that lol (pain in the ahole) i tried the car today and it started okay but didn't seem to idle very well and there seems to be no revs on the dash now if that makes sense the needle isn't moving any help would be awesome
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
