changing ecu
Old Oct 26, 2010 | 08:25 PM
spud-rs2k123's Avatar
spud-rs2k123
Default changing ecu
can i just change a non chipped ecu to a chipped ecu on my s2 with out causing any problems cheers
Old Oct 26, 2010 | 08:36 PM
studabear's Avatar
studabear
the car will need a set up at a tuner, if you swap it keep it of boost till its set up, otherwise you may kill the engine
Old Oct 26, 2010 | 08:47 PM
spud-rs2k123
at the moment its running about 8 psi will that be ok also do i have to change the black box to and do both ecus have to be the same code sorry for all the questions
Old Oct 26, 2010 | 09:23 PM
12_Second_rst's Avatar
12_Second_rst
all an rst turbo chipped ecu does is remove the boost limit all fueling setting will remain the same as above i wouldnt turn the boost up untill a tuner sets the metering unit up but theres no reason why you cant drive it as normal at the same boost that its running now,
as for the fuel ecu ( the black 1 ) some people say u can chip them but this will start a massive debate me perosnally ive only ever fitted chipped silver ecus and left the black one standard
there is different types of ecu u can tell by which pattern is on the front it will either be different colour squares or hearts and diamonds
none of these make any difference as they will all work but try and get one the same if u can
hope this helps
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
DixieTheKid
Sep 14, 2015 09:04 PM
tib2220
Sep 14, 2015 12:33 PM
marky_g
Sep 12, 2015 04:26 PM
