Do I need the oil modine? 2wd track saff
Old Jan 26, 2005 | 06:35 PM
Mr C's Avatar
Mr C
Default Do I need the oil modine? 2wd track saff
Do i need this heat exchanger?, and how will it affect the water and oil temps on start up and when driving it hard, I just want minimal fuss on my YB without putting the engine in danger mind!
Old Jan 29, 2005 | 07:16 PM
Mr C's Avatar
Mr C
BTTT
Old Jan 30, 2005 | 10:14 AM
alan rainbow's Avatar
alan rainbow
if your useing a oil cooler no but if not i would leave it on
Old Jan 30, 2005 | 04:16 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the modine oil/water heat exchanger works in 2 ways. firstly it helps to get the oil up to working temperature quicker by using the water (that heats relatively quickly) to heat it, but then once the oil is tending to get hotter than the water it will work the other way around and use the water to cool the oil (as heat transfer can only take place from a hot thing to a cooler thing).
i would use it, unless it proves to be inadequate at keeping oil temps down in which case, as alan says you should be using a air/oil heat exchanger.
personally, if you are considering an air/oil, i would add it to the water/oil one, as an air/water one is no use if the car's not moving (for example in the paddock during idle cool down)
Old Feb 1, 2005 | 08:27 PM
Mr C's Avatar
Mr C
Thanks Foreign RS, more to think about, CheeRs .
FlashRS
13
Aug 31, 2015 06:02 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
Roosie
Aug 9, 2015 07:37 AM
