ford focus st3 (wont start)
Old Oct 24, 2010 | 03:56 PM
dazdaman1985's Avatar
dazdaman1985
Default ford focus st3 (wont start)
Hi all im hoping some one might be able to help me i ahve a for docus st3 this morning i went round to a pals then when i went to drive the car again the engine is just not kicking in it is just making a clicking noise any help as to wat the problem may be would be very much appreciated thanks daz
Old Oct 24, 2010 | 04:10 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
flat battery? mine was clicking when my battery died?
Old Oct 24, 2010 | 04:14 PM
dazdaman1985
te cd player still comes on and plays though so i dont see how it could be the battery
Old Oct 24, 2010 | 04:18 PM
baggy1979's Avatar
baggy1979
RS geek
Hi mate put a multimeter across the battery and see what voltage you have?
Old Oct 24, 2010 | 04:23 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
lol
battery is prob so low it wont turn over the engine but theres enough to power the stereo
push start it and see how that goes
Old Oct 24, 2010 | 04:26 PM
dazdaman1985
the car opens with the key and everything works ie stereo lights etc. i have the electronic start button when it tells me to push the clutch to start so i do thats then when it clicks but is not starting the engine!!!! does this sound like the prob u had???? manythank daz
Old Oct 24, 2010 | 04:58 PM
paul16v's Avatar
paul16v
Monte 087
As said mate flat battery, it takes alot more to turn the engine over than it does to make the cd player etc work.
Old Oct 24, 2010 | 06:25 PM
RichieST's Avatar
RichieST
Flat battery. Have you been using the car for lots of short trips?
Old Oct 30, 2010 | 03:25 PM
martysmartie's Avatar
martysmartie
As said it's a flat battery either it's not charging or the battery needs replacing, the CD player will tell you nothing but if you switch the headlights on and then tried starting they should go dim confirming the problem, you could always bump/jump start as a temporary measure to get you on your way.
Martin
taylora1409
Aug 12, 2015 12:06 PM
