genuine and non genuine pannels
Old Oct 22, 2010 | 07:39 PM
conor.rst's Avatar
conor.rst
Default genuine and non genuine pannels
apart for the price tags. is there much differece between the two.
Old Oct 22, 2010 | 09:04 PM
orionmojo's Avatar
orionmojo
non geniune will need some fettling to get to fit at all, and quite abit more to get them perfect.
having said that though the company you buy from is probably a big factor.
Old Oct 22, 2010 | 09:10 PM
jamie rst's Avatar
jamie rst
non genuine panels take more fitting as they do not line up great and they are made from a cheaper metal,
but you can get them to fit right mate as both front wings on my car are not genuine ones as is the front panel but the front panels are not great as the hole cut out are $h!t but then again mine are all filled in lol
Old Oct 23, 2010 | 09:00 AM
Marc LJX's Avatar
Marc LJX
I had the option of replacing both front wings on my Mk3 during resto due to some rot up at the top near the scuttle panel.
My mate who prepped it said that the existing (original) wings repaired would still last longer than brand new non gen ones...
Old Oct 23, 2010 | 09:39 AM
phil_rs's Avatar
phil_rs
yam yammer
A friend of mine fitted a none genuine crossmember to his mk4 escort and nothing would fit right! He managed to find a new/old stock genuine part which was, of course, a perfect fit and everything fitted. If I was restoring an old escort, especially an RS model, I would only use genuine panels. If I couldn't find them then I would buy a MINT car already sorted!
Old Oct 23, 2010 | 09:49 AM
essexRSTSouthend's Avatar
essexRSTSouthend
Thats put me off replacing my front now.so got lots of fun ahead of me.
Old Oct 23, 2010 | 10:13 AM
Ryan_3's Avatar
Ryan_3
depends on the quality and companeis mate. some imitation panels are spot on, and soem original panels needs fettling with!!
Old Oct 23, 2010 | 10:22 AM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
as said it can really be night n day when it comes to the difference ,
and rember not all aftermarket panels are mate in the same place , weve had italian ones , chineese and jobbies made in tiwan ,
a panel beater worth his salt could make a aftermarket panel fit and look spot on ,
granted if budget allows and there available id say go gen , but in current times there either way overpriced of just not available ,
as for how long it will last , any panel gen or not will only last to the same extent as how its prepped n fitted and how the cars looked after ,
me and karl have been working on a s2 that had sills fitted , cant be that old , as the sticker inside was like new , but it had rot to bits as when they fitted it they bare metal'd there areas to weld and never protected the areas ,
99% its all down to shoddy workmanship ,
beef
Old Oct 23, 2010 | 12:03 PM
muz's Avatar
muz
Wye Valley Hardcore
I fitted 2 front wings and a front panel to a MK3 fiesta. The front panel and one wing were Hadrian and one wing was genuine Ford. To be fair, the Hadrian wing fitted perfectly, exactly as the Ford one did and the front panel only needed minor playing with. I think Hadrian are, or used to be the best copies, but I think even they have stopped making certain Ford panels.
Old Oct 23, 2010 | 06:59 PM
escort_rst's Avatar
escort_rst
im after panels and when i rang hadrian they gave me a number for my nearest panel shop. is this right? will the panels be ordered from hardian? cheers
bobsworth
77
Mar 24, 2016 09:30 PM
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mark_
40
Oct 2, 2015 04:40 PM
Sep 28, 2015 10:05 AM
