Handbrake adjustment problem
Old Oct 22, 2010 | 03:44 PM
DanFraser's Avatar
DanFraser
Default Handbrake adjustment problem
What am I looking to adjust on the rear drums or handbrake cable when one side locks hard on two clicks but the other side only locks hard between 3 and 4 clicks? On two clicks it is fairly easy to rotate the drum by hand. I've had both sides clicking on pressing the brake pedal after managing to blindly unhook the adjuster thing in both drums but it continues to be out of balance on one side.
MOT failure code was 3.7.A.9 and after playing with the brakes found one side was looser than the other resulting in the poor braking efficiency on the RBT.
Old Oct 25, 2010 | 09:45 PM
James998's Avatar
James998
I'm not sure what you're asking? Wind the adjusted around (Lengthening) on the 'looser' side if that helps.
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
