starting problem help lads
Old Oct 21, 2010 | 08:24 PM
martin27's Avatar
martin27
Default starting problem help lads
hi lads i bought a s2 fixed all problems so fare with the help ov use lot an thank now am having trouble with it starting it takes ages for it 2 start the lad who i go it off put new metering unit on it and i have put new dizzy unit on when it starts up seems 2 run fine any ides lads
Old Oct 21, 2010 | 08:34 PM
studabear's Avatar
studabear
might need a set up
Old Oct 21, 2010 | 08:39 PM
martin27's Avatar
martin27
think dizzy timing is out i put it 2 the both marks thanks for that help ov day m8 cars nearly there now
Old Oct 21, 2010 | 08:42 PM
PUDSEY1911's Avatar
PUDSEY1911
Try using a timing light to set the dizzy and make sure valve timing is ok.
Old Oct 21, 2010 | 08:48 PM
martin27's Avatar
martin27
do use think it could be dizzy timing
Old Oct 22, 2010 | 06:35 PM
project rs's Avatar
project rs
could be timing or your fueling is out could be the cold start valve is playing up, does it start like this all the time or is it better when hot or cold
JoeyBoyden
Jan 4, 2024 02:36 PM
mk22door
49
Mar 26, 2022 07:15 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
