MK4 Escort - Lost key
Old Oct 19, 2010 | 04:20 PM
CalibreDan's Avatar
CalibreDan
Default MK4 Escort - Lost key
Meant to be getting a MK4 Escort off a mate tonight but he's lost the key - Will a locksmith be able to make a key up, or is it easier to just somehow get in it, hotwire it then get a new lockset? Any help please gents because I'm meant to be picking it up ASAP
Old Oct 19, 2010 | 04:34 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
A locksmith will be able to make you a key, but it'll most likely cost more than a lockset!!
Old Oct 19, 2010 | 04:41 PM
mulla's Avatar
mulla
pmd
Old Oct 19, 2010 | 04:42 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
take the door locl out there will be a number on it go to Ford they will cut you a key
Old Oct 19, 2010 | 04:43 PM
rsfido_1989's Avatar
rsfido_1989
De lock it lol can pm how to start with no keys if needed
Old Oct 19, 2010 | 04:44 PM
paul16v's Avatar
paul16v
Monte 087
Any decent lock place will cut you a key from a lock, cheaper than ford aswell.
Old Oct 19, 2010 | 05:09 PM
mentalasanything's Avatar
mentalasanything
If you're feeling fruity, you can easily take the lock apart. Each of the cams are numbered inside and if you write down the numbers in order you can then go to a locksmith and get it cut.
I have recently re-coded a few tibbie locks and it's surprisingly easy.
Lee
Old Oct 19, 2010 | 06:20 PM
As said some of the door locks have the number stamped on them.
Dead easy to get into anyway without key, and even easier to start, steering lock can be made "unlocked" easy, bit fiddly but causes zero damage so when key is sorted it still woks perfect.
Old Oct 21, 2010 | 02:44 PM
CalibreDan's Avatar
CalibreDan
Cheers guys
Tabetha, any info on that? Been too busy to get it sorted and the car needs moving tonight, was going to get in and get a lock out to take to a locksmith but haven't got enough time to do that so going to have to get in it, do the steering lock and start it... Would prefer to not do any damage because it's so mint!
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
tankybaby66
Aug 9, 2015 07:13 AM
