boost gauge fitting
Hi bit long winded but i,ve been meaning to sort this out for a while , the problem i have is there is no where to 'T' into the inlet unless taken off and have a new thread made , i wont use the map pipe or FPR pipe , the only one i can see to use is where the dump valve pipe is located its a BSP fitting adapted to fit the JIC spec r braided hose for the dump v .
Anyone had this problem , surely someone has come across this one before?
i want my dump valve and boost guage working from the same point , the pipe to guage is the see through flexy rubber type that will push over a small tube . i do have another guage that is small black plastic type pipe that could have an olive fitting .
Any recommendations or links as i cant find two adaptors to suit
cheers
mike
cheers
mike
mrmann
Aug 20, 2015 11:24 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
