t34 limits
was out yesterday doing some hi end mapping and think we may have reached the limits of a t34.48 on a 1.6 as we have a spike of 2.4 bar at 3800 but it drops again over a couple of hundred revs to 1.9/2 bar to the limiter (7000) and no matter what we did could not hold any more and think this might be due to the back pressure of the housing so just thought i'd share what we experienced with you all especially the lads thinking of putting the t34 on there cars, over winter i'll be trying some nos and will report back on what it does to spool and power through out the rev range, p.s i'll be at pod this weekend if any of you want any info or maybe a passenger ride if we have time etc
sounds good as im running t34.48 and greys and was looking to run about 2bar so i know that there is a little left in the turbo ... sounds like its going to be fun....
and i would mind a passenger ride so i can get a feel for what mines going to be like when its done in early 2011
im coming up on sunday to speak to crazycage
it's on greys and there at 90% duty on full chat and rsmark just bring a crash hat if you happen to have one as hopefully be over the 110 mark and you'll probably find me and crazy fiddling somewhere
im a bit pissed off as i spoke to my mate at jamsport and it turns out that my gotech mfi has a internal map sensor thats rated to about 22psi so he thinks it wont be upto the job of 2bar+ .
he said to just set it up and see how it goes but to be honest i cant be arsed i just want it done once and only once.... so im going to sell the gotech and get ms or cossie management
wicked ive got a bike anyway so will have to crack it out....
what power would it make at 1.5 bar with t34.48 stage3 and big spec cvh with newman ect....
and how much is a full diy kit for ms with every part needed and i will fit and then pay you to mapp
not sure on the cost for the full kit ,try diy-auto tune.
i dont do much mapping ,im just a fabricator/welder.
my ms2 cost me £225 and i payed £50 for the 5 bar map sensor. you could do it all for under £500 easy. ricks your man for mapping .
Russ Payne
Sep 25, 2015 08:29 PM
