2wd exhaust manifold
Old Oct 13, 2010 | 08:38 PM
Paul_RS's Avatar
Paul_RS
Default 2wd exhaust manifold
How does the turbo secure to a 2wd exhaust manifold? The 4wd manifold has studs in it but the 2wd does not?
Old Oct 13, 2010 | 09:58 PM
LHD220Turbo's Avatar
LHD220Turbo
i'm pretty sure the 2wd has studs in wth nuts in them too?
Old Oct 14, 2010 | 07:30 AM
I've just done mine, the turbo flange has studs in it, that go through the flange in the top part of the trousers, the bottom doesn't this secures to the manifold via 4 bolts 2 go underside 2 go top side and pass through the flange on the end of the trouser's base.
Old Oct 14, 2010 | 05:39 PM
Paul_RS's Avatar
Paul_RS
None i've seen have a stud in the turbo section? My manifold has no threads in that part? My turbo hasn't any threads in it either, so would i be OK using nuts and bolts?
Old Oct 14, 2010 | 06:40 PM
I'm going by(bad) memory and a picture I found of some ones car on the rollers where it sure looks like studs in the turbo flange that go through the trousers top part.
Nuts and bolts will be fine, make your own K nuts and they won't need lock washers and won't come undone either.
K nuts can be made by squeezing the nuts in a vice to make the hole slightly oval, there's a knack to getting the squeeze right, but well worthwhile thing to do.
Old Oct 14, 2010 | 07:26 PM
bad boy rs's Avatar
bad boy rs
ive got my tt t38 4x4 back housing on a 2wd manifold, using bolts with lock nuts been fine for ages
Old Oct 14, 2010 | 07:32 PM
charlie luciano's Avatar
charlie luciano
4 nuts n bolts on mine no drama's
Luciano
jessie_rs
62
Aug 6, 2019 09:27 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
mark r
Sep 29, 2015 07:27 PM
Si B
Sep 12, 2015 06:49 AM
dojj
28
Sep 11, 2015 10:00 PM
