escort rs turbo f reg
Old Oct 12, 2010 | 10:09 PM
martin27's Avatar
martin27
Default escort rs turbo f reg
hi lads ive just bought an rs it had been stood a year the lad i got it off put a new metering unit on it . it woz missing when i got it dizzy timing woz out i drove it up street but doesnt pull like it should its had a new turbo wot can i do my self 2 make her run better ive turned a screw with a spring on it near top ov engine dont no wot its for dont no much about these cars plz help me
Old Oct 12, 2010 | 10:21 PM
phil_rs's Avatar
phil_rs
yam yammer
My advice!? Don't touch it!! Get it to someone who knows what they are doing
Old Oct 13, 2010 | 06:08 AM
Karlos G's Avatar
Karlos G
Balls Deep!
I agree, it sounds like you may to more harm than good!
A good setup will cost £140 tops!
Old Oct 13, 2010 | 06:14 AM
chaffe's Avatar
chaffe
Turbocharging Technician
When was the timing belt done last if it was stood up for a year? be carefull mate, welcome to the club though
Old Oct 13, 2010 | 07:02 AM
craig rst kid's Avatar
craig rst kid
as above get a good set up from a reputable rs tuner try not 2 mess with t yourself as it could end in tears and new engine needed m8
Old Oct 13, 2010 | 05:58 PM
martin27's Avatar
martin27
Default rs turbo
thanks lads were do i start with tunning it cars not been modified at all payed 800 for it woz it worth it cars clean
Old Oct 13, 2010 | 06:17 PM
craig rst kid
depends on how much rust in the areas they usually suffer with like battery tray ,boot,sunroof,sills floor pan front panel behind the bumper just ive it a good look over as for tuning the nearest one reputable tuner to you is motorsport developments in blackpool just wouldn't thrash it too much till its set up oh and you have norris motorsport in Derby
Old Oct 13, 2010 | 06:30 PM
martin27's Avatar
martin27
theres just a bit near sun roof and probley neads new boot a part from that looks ok theres a place near me called well lane turbos dont no if its any good wots that place near black pool like thanks matin
Old Oct 13, 2010 | 06:38 PM
craig rst kid
www.motorsport-developments.co.uk never heard anything bad about them mate an www.norrismotorsport.co.uk same as i am sure a few of the lads on here have used them and had good results get in touch with either of them havent heard anything about well lane turbos may be worth asking some of the lads more locally if there any good with mfi rsts
Old Oct 13, 2010 | 06:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cant go wrong with either, both excellent tuners!
Old Oct 13, 2010 | 07:01 PM
martin27's Avatar
martin27
would the car be ok 2 drive down there like that m8
Old Oct 13, 2010 | 07:31 PM
craig rst kid
try not to stay on boost if possible take it easy it should b fine mfis are prone to be running very lean if not set up on a regular basis and thats what scrapped my last bottom end too much boost not enough fuel just take it easy and you should be fine mate it could be running a bit rich in lower rpm but a little bit rich is way safer than too lean
Old Oct 13, 2010 | 08:04 PM
martin27's Avatar
martin27
thanks alot for this mate when i drove it up steet u could not really feel boost that much dont no if its coz its been stood or lads messed all seting up with changing fuel metre and dizzy timing woz out and dont no if ive set that right when u rev it up u can hear turbo i turn a screw with a spring on it all the way in near siver pipe wot at top ov engine wot turbo goes 2 do u no wot its for thanks
Old Oct 13, 2010 | 08:32 PM
martin27's Avatar
martin27
plz help me lads
Old Oct 13, 2010 | 09:36 PM
martin27's Avatar
martin27
plz plz
Old Oct 14, 2010 | 09:52 AM
craig rst kid
can you get a picture up mate as said above though i wouldn't tamper with it anymore motorsport developments have got an offer for set ups at the moment for set ups less than 120 plus vat trust me mate its well worth getting it sorted now than leaving it to get worse plus with a good set up you will find it will be more responsive hope this helps motorsport developments are a trader on this site speak to them
Old Oct 14, 2010 | 10:57 AM
martin27's Avatar
martin27
thanks pal
Old Oct 14, 2010 | 01:11 PM
craig rst kid
no worries mate
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
