Speedo question
Old Oct 12, 2010 | 04:32 PM
onionlover's Avatar
onionlover
Default Speedo question
Removed the instrument panel at the weekend trying to fix a problem that turned out to be a fuse (doh!). Disconnected the speedo drive from the speedo when i removed the panel. I've reconnected it since and now it just bounces around at about 20-30mph regardless of actual speed. Anyone had this before and is it just a re-calibration of the speedo or does it need replacing? Cheers
Old Oct 12, 2010 | 04:56 PM
nigel b's Avatar
nigel b
pull the cable off the speedo again and make sure you align it up correctly when re fitting it
Old Oct 12, 2010 | 04:58 PM
onionlover's Avatar
onionlover
Are there any alignment marks on the cable or the speedo unit to help alignment or is it just trial and error
Old Oct 12, 2010 | 09:14 PM
nigel b's Avatar
nigel b
im sure its a square drive
you should be able to tell when you put the cable in what it feels like
im trying to remember as i havent had a speedo cable for 6+years
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
