2wd sump / oil pump ?
Ive got a rebuilt 200 block which has been sitting in the garage for months, plan tonight was to fit my big wing sump and a few other bits.
Now i new i was going to have to change the 4x4 pick up for a 2wd item, but to me they look the same ?
prob is my sump wont fit with the 4x4 pick up as its fouling on part of the sump
heres a pic
you can see the sump needs to move around 10mm to seat right, its sits flat on the block but needs to move forward.
you can see here where its fouling
i cant see changing the pick up will solve this, any ideas ?
cheers paul
heres a pic
cheers paul
JK12
33
Apr 26, 2021 12:09 PM
